SM-SRE and VRF
Arvyr
I recently added a SM-SRE-910 to my collection of lab equipment.
I got a question regarding vrfs.
So I set up a loopback interface, put it in a vrf and used this as ip unnumbered for the embedded-service-engine (cimce) and sm (esxi) interface.
What's strange is, that the loopback's ip is in the correct routing table, whereas the emb and sm interfaces are in the global one.
In my scenario I want the managemant traffic separated from voice and other data, so I created a couple of sub-interfaces on gi0/0.
Part of the config:
interface Loopback0
description *** MGMT-GW + NTP SOURCE ***
vrf forwarding mgmt
ip address 10.20.4.1 255.255.0.0 secondary
ip address 10.20.0.1 255.255.0.0
end
interface Embedded-Service-Engine0/0
description *** CIMC-E INTERFACE ***
vrf forwarding mgmt
ip unnumbered Loopback0
service-module ip address 10.20.3.1 255.255.0.0
service-module ip default-gateway 10.20.0.1
service-module enable
end
interface SM1/0
description description *** UCS-E INTERFACE ***
vrf forwarding mgmt
service-module ip address 10.20.1.1 255.255.0.0
!Application: VMware ESXi 5.1.0 build-1065491 running on SRE
end
interface GigabitEthernet0/0.21
description *** MGMT-ACC INTERFACE VLAN21 ***
encapsulation dot1Q 21
vrf forwarding mgmt
ip address 10.21.0.1 255.255.0.0
ip virtual-reassembly in
end
ip route 10.20.1.1 255.255.255.255 SM1/0
ip route 10.20.3.1 255.255.255.255 Embedded-Service-Engine0/0
So when I try to ping either of these 2 interfaces via a device coming from gi0/0.21, I cannot reach them.
Pinging the loopback interface however works perfectly.
So what's the solution here? I tried it with bgp route leak or whatever. I might got something wrong there or it's not supposed to work like that.
All I want is both static routes to be found in the correct mgmt vrf.
Any help is much appreciated.
#show ip route:
 10.20.0.0/16 is variably subnetted, 3 subnets, 2 masks
C 10.20.0.0/16 is directly connected, Embedded-Service-Engine0/0
S 10.20.1.1/32 is directly connected, SM1/0
L 10.20.3.1/32 is directly connected, Embedded-Service-Engine0/0
#show ip route vrf mgmt:
 10.20.0.0/32 is subnetted, 2 subnets
C 10.20.0.1 is directly connected, Loopback0
C 10.20.4.1 is directly connected, Loopback0
10.21.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 10.21.0.0/16 is directly connected, GigabitEthernet0/0.21
L 10.21.0.1/32 is directly connected, GigabitEthernet0/0.21
6 Replies 6
Deepak Kumar
Your static routes are configured in global VRF.
Your route commands must be as
ip route vrf mgnt 10.20.1.1 255.255.255.255 SM1/0
ip route vrf mgnt 10.20.3.1 255.255.255.255 Embedded-Service-Engine0/0
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
I already tried that one, but it doesn't work with the interfaces in question.
Erorr message says
% For VPN or topology routes, must specify a next hop IP address if not a point-to-point interface
I wouldn't ask, if it were that easy ;)
Hello
FYI - Any subnet assigned to a VRF will ONLY be seen in that vrf table, As your aware by default the vrf table and the global routing table are separate so will not be able to reach each other.
So if you need for the vrf routes to reach a subnet residing outside it own vrf table lets say in the global rib then you need to tell the rtr how to reach it.
Example
172.16.10.0/24 VRF mgt - int fa0/0
10.10.10.0/24 global rib:
ip route vrf mgt 10.10.10.0 255.255.255 (xxx next hop)  global
ip route 172.16.10.0 255.255.255.0 fa0/0
Kind Regards
Paul
since the routes are needed to access specific interfaces, i cannot specify another next hop but another one on the router, wich doesn't work.
I cannot use ip route 10.20.1.1 255.255.255.255 SM1/0 global (that statement isn't available here)  nor give a next hop such as ip route 10.20.1.1 255.255.255.255 10.20.0.1 because it's the same router.
Hello
maybe I have misunderstood- please confirm you are wanting to access subnets in different vrfs on the same router
Kind Regards
Paul
Yes, that is exactly what i want to do.
But it's more like, the same subnet, wich seems to be on different vrfs due to the fact, that the command
service-module ip address x.x.x.x y.y.y.y
automatically puts this address into global vrf, even though the smx/y interface itself and the loopback I use as unnumbered is in the correct mgmt vrf.
There's no way to use something like "service-module vrf mgmt ip address" ...
