Two internet connection on router
junaid haroon
I have Cisco router 2611 in branch,there is internet connectivity and IPSEC VPN between branch and head office.
I want two configure the second ISP internet link on router for backup,if one ISP connection fails router will automatically shifts on second one
how i achieve this.below is my current router configurations.
version 12.4
hostname Store_RTR
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
no ip domain lookup
voice-card 0
archive
 log config
  hidekeys
crypto isakmp policy 10
 hash md5
 authentication pre-share
 group 2
 crypto isakmp key *************** address 124.109.34.78
crypto ipsec transform-set tset esp-des esp-md5-hmac
crypto map smap 10 ipsec-isakmp
 set peer 124.109.34.67
 set transform-set tset
 match address 101
interface FastEthernet0/0
 ip address 98.87.223.43 255.255.255.252
 ip nat outside
 crypto map smap
 no shut
interface FastEthernet0/1
 ip address 192.168.3.254 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
 no shut
i
ip route 0.0.0.0 0.0.0.0 58.27.221.41
ip http server
no ip http secure-server
ip nat inside source list 111 interface FastEthernet0/0 overload
access-list 101 permit ip 192.168.3.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.3.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 101 permit ip 192.168.3.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 101 permit ip 192.168.3.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 111 deny   ip 192.168.3.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 111 deny   ip 192.168.3.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 111 deny   ip 192.168.3.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 111 deny   ip 192.168.3.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 111 permit ip 192.168.3.0 0.0.0.255 any
route-map nat permit 10
 match ip address 111
control-plane
mgcp fax t38 ecm
scheduler allocate 20000 1000
end
2 Accepted Solutions
Ashok Kumar
You can achieve this by floating static route configuration.
Generally we use default routes for the such setup.
In your case, just configure 2 default routes & put some administrative value higher than the default (viz. 1 for static)
Here's what you need to do:
ip route 0.0.0.0 0.0.0.0 <primary ISP next-hop IP add>
ip route 0.0.0.0 0.0.0.0 <secondary ISP next-hop IP add>  <administrative distance(0-255)>  # use any value greater than 1 #
Other solution is to configure static routes with TRACK
1. Create Track
2. Map Track with IP SLA  ICMP-ECHO Operation to check the reachability
3. Add Track with static route configuration e.g.
ip route 0.0.0.0 0.0.0.0 <next-hop-ip> track 1
let me tell best option:
1. Configure the 2 static routes with difference in AD values to serve as primary /seconday
2. Create Track & IP SLA ......# this will check if the ISP gateway IP is reachable or not, track will go down once the ISP gatewat becomes unreachable #
3. Configure the Static route with Track as below:
ip route 0.0.0.0 0.0.0.0 <next-hop-ip-address> track 1
# this route will stay in routing table as long as the Track status is up, means ISP gateway is reachable, if the Track goes down, route will be removed from the routing table & then routing will be done fall back to alternate available routes
7 Replies 7
Khalid Qazi
Hi Junaid ,
Kindly share your topology , like link  coming on serial or Ethernet etc so we can give you solution as as per above request there are multiple solution is available like Multihome , CEF etc ..
Second link will be ADSL.
Ashok Kumar
1. Create Track
When 1st link goes down its will shift traffic on secondary one when primary will again up then what happens with traffic either it will remain on second link or use primary???
When primary will come up, as per administrative distance, primary route will be selected being default AD of 1
Great if we can achieve this with just satic routes can you tell me what is purpose of IP SLA.
I mean what is main difference??
