Two isp connections in 2911 router &one nat network in inside network
rakesh4
I have 2 ISP connections, one with 10 Mbps and another 10 Mbps.
I want two links to work together simultaneously two 10 Mbps link in one Nat network of 192.168.1.0/24
I have a Cisco router 2911(3 Interfaces only)
in inside how to achieve this
like i will use one ISP traffic for voice
another ISP traffic for data and use class c address 192.168.1.0/24
in this half of the hosts means 128 hosts for data and remaining for voice.
How i can configure the router to achieve this ?
please help anyone.
no protocols or other is used.
like below topology
Can anyone help me ?
have  a look at the link below, it uses PBR and also a failover mechanism in case one of your links goes down. If you get stuck, post the full config of your router so we can fill in the necessary bits and pieces...
https://community.cisco.com/t5/network-architecture-documents/dual-internet-links-nating-with-pbr-and-ip-sla/ta-p/3126275
hi thanks for reply
actually my target is at a time voice traffic goes to 100 users and data goes to another 100 users
it is possible
i am using using sub netted IP like 192.168.1.0/25 and 192.168.1.128/25 is possible?
192.168.11.0 to 192.168.1.127 =voice traffic
192.168.1.128-192.168.1.254=data traffic
it is possible to configure single inside interface using pat
please tell me
thanks for your reply George
Here my target is ISP 1 is using 192.168.1.0 to 192.168.1.128 IP addresses for voice
ISP 2 is using 192.168.1.129 to 192.168.1.255 IP addresses for data
here using sub-netted IP in single inside 2911 router
it is possible for using policy based routing
Kindly tell me
your access lists have to match the ports used for voice. Post the configuration of your router...
