Cisco 1921 Multicast
jmmgrodrigues
Hi!
I want to pass muticast traffic from WAN to VLAN interface but it's not working. I'm sure that is missing something but I'm not seeing what. I appreciate your help. Thanks!
Router#sh ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         192.168.1.15    YES NVRAM  up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0/0       unassigned      YES unset  up                    up
GigabitEthernet0/0/1       unassigned      YES unset  administratively down down
GigabitEthernet0/0/2       unassigned      YES unset  up                    up
GigabitEthernet0/0/3       unassigned      YES unset  up                    up
NVI0                       192.168.1.15    YES unset  up                    up
Tunnel0                    192.168.1.15    YES unset  up                    up
Vlan1                      unassigned      YES unset  administratively down down
Vlan10                     10.0.10.30      YES NVRAM  up                    up
Vlan20                     10.0.20.2       YES NVRAM  up                    up
Vlan30                     10.0.30.14      YES NVRAM  up                    up
Vlan105                    10.0.105.6      YES NVRAM  up                    up
Router#sh run
Building configuration...
Current configuration : 4702 bytes
! Last configuration change at 22:03:12 GMT Tue Sep 25 2018 by someone
version 15.5
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
clock timezone GMT 0 0
clock summer-time GMT recurring
ip dhcp excluded-address 10.0.10.1
ip dhcp excluded-address 10.0.10.25 10.0.10.30
ip dhcp excluded-address 10.0.20.2
ip dhcp excluded-address 10.0.30.2
ip dhcp excluded-address 10.0.30.11 10.0.30.14
ip dhcp excluded-address 10.0.105.2 10.0.105.6
ip dhcp pool 10
 network 10.0.10.0 255.255.255.224
 default-router 10.0.10.30
 dns-server 1.1.1.1 1.0.0.1
ip dhcp pool 20
 network 10.0.20.0 255.255.255.252
 default-router 10.0.20.2
ip dhcp pool 30
 network 10.0.30.0 255.255.255.240
 default-router 10.0.30.14
ip dhcp pool IPTV
 network 10.0.105.0 255.255.255.248
 default-router 10.0.105.6
 dns-server 192.168.1.254
ip name-server 192.168.1.254
ip multicast-routing
ip inspect log drop-pkt
ip inspect audit-trail
ip inspect name Default http
ip inspect name Default https
ip inspect name Default ftp
ip inspect name Default ftps
ip inspect name Default tftp
ip inspect name Default pop3
ip inspect name Default pop3s
ip inspect name Default imap
ip inspect name Default imaps
ip inspect name Default tcp
ip inspect name Default udp
ip inspect name Default icmp
ip inspect name Default dns
ip inspect name Default telnet
ip cef
no ipv6 cef
parameter-map type inspect global
 log dropped-packets enable
 max-incomplete low 18000
 max-incomplete high 20000
license udi pid CISCO1921/K9 sn XXXXXXXXXX
username xxxxx privilege 15 password 7 xxxxx
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description *** WAN ***
 ip address 192.168.1.15 255.255.255.0
 ip access-group Default in
 ip nat outside
 ip inspect Default out
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/0/0
 description *** Switch ***
 switchport trunk allowed vlan 1,10,105,1002-1005
 switchport mode trunk
 no ip address
interface GigabitEthernet0/0/1
 no ip address
 shutdown
interface GigabitEthernet0/0/2
 description *** AP 2 ***
 switchport trunk native vlan 30
 switchport trunk allowed vlan 1,30,1002-1005
 no ip address
 speed 100
interface GigabitEthernet0/0/3
 description *** AP 1 ***
 switchport trunk native vlan 10
 switchport trunk allowed vlan 1,10,20,1002-1005
 no ip address
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 ip address 10.0.10.30 255.255.255.224
 ip nat inside
interface Vlan20
 ip address 10.0.20.2 255.255.255.252
 ip nat inside
interface Vlan30
 ip address 10.0.30.14 255.255.255.240
 ip nat inside
interface Vlan105
 ip address 10.0.105.6 255.255.255.248
 ip pim sparse-mode
 ip nat inside
 ip igmp join-group 224.0.1.40
 ip igmp version 3
ip forward-protocol nd
no ip http server
no ip http secure-server
ip pim rp-address 192.168.1.254
ip nat inside source list 10 interface GigabitEthernet0/0 overload
ip nat inside source list 20 interface GigabitEthernet0/0 overload
ip nat inside source list 30 interface GigabitEthernet0/0 overload
ip nat inside source list 40 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.254
access-list 10 permit 10.0.10.0 0.0.0.31
access-list 20 permit 10.0.20.0 0.0.0.3
access-list 30 permit 10.0.30.0 0.0.0.15
access-list 40 permit 10.0.105.0 0.0.0.7
control-plane
 vstack
line con 0
 exec-timeout 15 0
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 15 0
 login local
 transport input telnet
scheduler allocate 20000 1000
ntp source Vlan10
ntp server pt.pool.ntp.org prefer
ntp server europe.pool.ntp.org
end
Router#sh ip igmp snooping groups
Vlan      Group                    Version     Port List
105       239.195.7.2              v3          Gi0/0/0
105       239.196.1.35             v3          Gi0/0/0
105       239.255.255.250          v3          Gi0/0/0
Router#sh ip igmp snooping mrouter
Vlan    ports
 105
Heeeeelp!!!
7 Replies 7
johnd2310
Level 8
Level 8
When you enable multicast, you need to ensure you have pim configured along the whole path. In you config you have pim configured on vlan 105 only, you need pim on all participating interfaces. If multicast is coming from the WAN, then configure pim-sparse on Gi0/0
John
**Please rate posts you find helpful**
Hi John,
I've already done that. Used ip pim sparse-mode in WAN and VLAN with rp-address at general config and ip pim dense-mode on both interfaces without rp-address. But the image still stops. The output I have is:
Router#sh ip igmp groups
IGMP Connected Group Membership
Group Address    Interface                Uptime    Expires   Last Reporter   Group Accounted
239.195.1.109    Vlan105                  00:00:36  00:02:44  10.0.105.1
239.255.255.250  Vlan105                  00:03:14  00:02:52  10.0.105.1
239.255.255.250  GigabitEthernet0/0       00:44:48  00:02:56  192.168.1.253
239.195.7.2      Vlan105                  00:03:14  00:02:46  10.0.105.1
224.0.1.40       Vlan105                  00:44:06  00:02:44  10.0.105.6
Router#sh ip igmp inter
GigabitEthernet0/0 is up, line protocol is up
  Internet address is 192.168.1.15/24
  IGMP is enabled on interface
  Current IGMP host version is 3
  Current IGMP router version is 3
  IGMP query interval is 60 seconds
  IGMP configured query interval is 60 seconds
  IGMP querier timeout is 120 seconds
  IGMP configured querier timeout is 120 seconds
  IGMP max query response time is 10 seconds
  Last member query count is 2
  Last member query response interval is 1000 ms
  Inbound IGMP access group is not set
  IGMP activity: 4 joins, 3 leaves
  Multicast routing is enabled on interface
  Multicast TTL threshold is 0
  Multicast designated router (DR) is 192.168.1.15 (this system)
  IGMP querying router is 192.168.1.15 (this system)
  No multicast groups joined by this system
Vlan105 is up, line protocol is up
  Internet address is 10.0.105.6/29
  IGMP activity: 7 joins, 3 leaves
  Multicast designated router (DR) is 10.0.105.6 (this system)
  IGMP querying router is 10.0.105.6 (this system)
  Multicast groups joined by this system (number of users):
      224.0.1.40(1)
Thanks!
I mightb be missing something, but where is your access list DEFAULT ? I don't see it in your configuration...
Hi John!
It's at WAN interface Gi0/0. It must be at VLAN interface too? Thanks!
I do not think that Georg was asking about where in terms of which interface but was asking where in terms of what part of the config has the content of the access list (we need to see what is permitted and what is denied and we do not see any of that).
Rick
Rick
Can you give us more details on your environment. Where is the multicast source, receiver and RP. If the source is on the WAN and the receiver on vlan 105, then you need the following interfaces configured for pim
interface Vlan105
 ip pim sparse-mode
  ip pim sparse-mode
I am not sure why you have "ip igmp version 3" and "igmp join-group 224.0.1.40". Do your applications really need igmp v3 support? I would remove them.
You also need your RP:
I am guessing the RP is on the WAN and therefore the WAN needs to have pim sparse-mode enabled all the way to the source.
You need to check that pim is working. Run "show ip pim neighbor". You should see pim neighbours. If not check the access lists on the Interface and configuration other router.
Run "show ip mroute". Verify required addresses are in routing table
post output of your show commands
John
Hello
It looks like your Mc configuration is inaccurate?
You have applied an igmp join group on vlan 105 that isn't applicable, basically stating this SVI interface to send query's towards the mc source  However for that address you've specified is the mc rp discovery address itself and not a mc group!
You also have a static default route and unicast rp pim-address specified towards 192.168.1.254 but i don't see interface gigi0/0 pim enabled
Static pim requires full reachability to the defined RP address for the mc groups and a pim mapping on every routed device between source and receiver.
So you wish for vlan105 users to receive mc traffic you could try enabling pim on your wan interface towards the RP, removing the igmp join group from vlan 105 and possibly apply igmp snooping for that vlan on your switches.
rtr
int gig0/0
ip pim sparse-mode
exit
int vlan 105
no ip igmp join-group 224.0.1.40
exit
ip pim autorp-listener
Switches:
ip igmp snooping
ip igmp snooping vlan 105
Kind Regards
Paul
