Two ISP to single Router
How to connect Two ISP to single Router and configuration???
Rajeev Sharma
Hey Ganesh,
You may use any protocol, however first check with your service providers about which protocol they are using.
However most of times itsBGP, so here is a good documentation for same:
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/23675-27.html
HTH.
RS
Rajeev Sharma
Hey Ganesh,
HTH.
RS
Thank you
Cheers :)
RS
kaaftab
Level 4
Level 4
can you elaborate the purpose of this yes BGP is usually used or if you just want to use the link for internet trafiic and load balancing you can use the ip sla with track option to achieve this .
