two isp, two networks & one router
seclucscon
Hi, I have 1 router (Cisco 2921), 2 ISP Link & 2 networks(one is 172.16.0.0 & another is 192.168.0.0).  I want to pass 2 networks by 2 different ISPs, like 172.16.0.0 will be passed by ISP 1 & 192.168.0.0 will be passed by ISP 2. I have 1 firewall attached with this router.
How can i do this in 1 router that  two network will be divided by two ISPs? How the natting will be done for 2 link??
Can anyone please help me in this issue urgently??
15 Replies 15
This should do the trick:
ip sla 1
icmp-echo 100.0.0.1
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 200.0.0.1
ip sla schedule 2 life forever start-time now
track 1 ip sla 1 state
track 2 ip sla 2 state
int g0/0
ip nat outside
int g0/1
ip nat outside
int LAN
description connection to ASA
ip nat inside
ip policy route-map PBR
ip route 0.0.0.0 0.0.0.0 next_hop_isp1 gi0/0 track 1
ip route 0.0.0.0 0.0.0.0 next_hop_isp1 gi0/0 track 2
ip nat inside source route-map isp1 interface FastEthernet0/0 overload
ip nat inside source route-map isp2 interface FastEthernet0/1 overload
ip access-list extended LAN1
permit ip 172.16.0.0 0.0.255.255 any
ip access-list extended LAN2
permit ip 192.168.0.0 0.0.31.255 any
access-list 10 permit 172.16.0.0 0.0.255.255
access-list 10 permit 192.168.0.0 0.0.31.255
route-map PBR permit 10
match ip address LAN1
set ip next-hop verify-availability 100.0.0.1 1 track 1
route-map PBR permit 20
match ip address LAN2
set ip next-hop verify-availability 200.0.0.1 1 track 2
route-map isp1 permit 10
match ip address 10
match interface Gi0/0
route-map isp2 permit 10
match ip address 10
match interface Gi0/1
What exactly do you mean by "merge 2 links"? With configuration above you are using both links in same time so traffic load is some sort of divided between both links.
If you want to implement more complex loadbalancing, take a look at Cisco Performance Routing PfR ->
http://blog.ine.com/2011/11/01/cisco-performance-routing-pfr-optimized-edge-routing-oer/
If you meant by "merge" to create some sort of "etherchannel" it is no possible.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
