Two / multiple inbound Dialer profiles in ISDN Bri possible? (1700 series)
hartwig.kempf
Hi there!
I configured two inbound dialer profiles on a 1721 router. Dialer1 is supposed to be the remote-connection for an IT professional who uses ISDN/modem Dialin. Dialer2 is used for a remote connection to another Cisco router and uses callback. Both dialers work successfully, when the other one is shutdown.
When none of the dialer is in shutdown, every call is bound to the Dialer1.
So, I need to direct the calls to the appropriate dialer according to the incoming number. Does any one has a solution for this case?
Thanks a lot!
b.hsu
Level 5
Level 5
This chapter presents the decisions and preparations leading to a dial-on-demand routing (DDR) configuration and shows where some advanced features fit into the DDR configuration steps. It distinguishes between the topology decisions and the implementation of the decisions. In the implementation phase, it distinguishes the DDR-independent decisions from the DDR-dependent decisions.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca720.html
