Two switches connection - unable to ssh to sw2
athens45
We have two l3 switches and one router.
SW1 connected to SW2 via trunk
And also connection from sw1 >>>10.253.255.101
to
sw2:
interface GigabitEthernet1/0/48  no switchport  ip address 10.253.255.102 255.255.255.252.
Made this for test, Idea is to have connection to sw2 also from client machine.
From User computers on sw1 we can do ssh to sw1, but not to sw2 (only possible ssh from sw1 directly).
Check config files of SW1 , SW2 and router.
All clients are connected on these two switches. How to make sw manageable from client machine.
Hello
Please review and if applicable amend to your exiting config.
SW2
default interface GigabitEthernet1/0/48
shut
no ip default-gateway 10.253.255.254
ip default-gateway 10.253.3.1
no ip routing
no ip device tracking
SW1
aaa authentication dot1x default group radius local
aaa authorization exec default group radius local if-authenticated
aaa authorization network default group radius local if-authenticated
line vty 0 15
login local
Kind Regards
Paul
luis_cordova
Hi @athens45
I suggest you create a vlan301 interface in Sw2 and assign it an IP.
Also, I see that in Sw1 the logging is by AAA and in Sw2 it is local.
You could leave the same method log on both switches.
Hello
SW2
shut
no ip routing
SW1
line vty 0 15
login local
Kind Regards
Paul
Deepak Kumar
Make some changes on the Switch 2 as:
no ip routing
Also, remove the Interface 48 configuration because this switch will work as L2.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
