tx-ring-limit and losing connection
travisll
We are trying to fine toon our QOS policies and in doing so we are lowering the tx-ring-limit on each of our pvc's.
When I lower it to 3 some of the branch locations loose connection back to the main router.
The configs on both ends are exactly the same. One location dill loose connection evertime and the other will not.
Here is the config at the main location
interface ATM0/1
no ip address
no scrambling-payload
ima-group 0
no atm ilmi-keepalive
interface ATM0/2
no ip address
ima-group 0
interface ATM0/IMA0
no ip address
ip nbar protocol-discovery
ima differential-delay-maximum 50
atm ilmi-pvc-discovery
interface ATM0/IMA0.1 multipoint
ip address 10.100.100.1 255.255.255.0
ip ospf network point-to-multipoint
pvc 1/33
protocol ip 10.100.100.8 broadcast
vbr-rt 384 384
encapsulation aal5snap
service-policy output AutoQoS-Policy-Trust
pvc 1/34
protocol ip 10.100.100.14 broadcast
vbr-rt 384 384
tx-ring-limit 3
pvc 1/35
protocol ip 10.100.100.100 broadcast
vbr-rt 384 384
tx-ring-limit 3
pvc 1/36
vbr-rt 384 384
tx-ring-limit 3
pvc 1/37
protocol ip 10.100.100.15 broadcast
vbr-rt 384 384
tx-ring-limit 3
pvc 1/38
protocol ip 10.100.100.17 broadcast
vbr-rt 384 384
tx-ring-limit 3
pvc 1/39
protocol ip 10.100.100.2 broadcast
vbr-rt 384 384
pvc 2/34
pvc 2/35
protocol ip 10.100.100.4 broadcast
vbr-rt 384 384
tx-ring-limit 3
pvc 3/34
protocol ip 10.100.100.50 broadcast
vbr-rt 384 384
tx-ring-limit 3
About 3 - 5 mins after I add tx-ring-limit to pvc 1/39
the branch losses connection.
As you can see I have the tx-ring-limit set and working on various other PVC's
Travis
travisll
Here is the other ends config also.
interface ATM0/0
no ip address
bundle-enable
dsl operating-mode auto
interface ATM0/0.1 point-to-point
bandwidth 384
ip address 10.100.100.2 255.255.255.0
pvc 0/35
protocol ip 10.100.100.1 broadcast
vbr-rt 384 384
tx-ring-limit 3
service-policy output QoS-Policy
