udp nat range port
Krasnoperov
Hello Cisco Employe&Experts
I have a question which lot of your customer bother (IMHO), when dnat function will work for UDP connection, my goal is do destination NAT for range of UDP port, it works for TCP, and work grate, why&when this will work for UDP?
ip nat pool P2P <inside IP> <inside IP> netmask 255.255.255.0 type rotary
-           ip nat inside destination list 111 pool P2P
-           access-list 111 permit tcp any any range 2000 2100
I found this
CSCsk86712 and status is closed
7 Replies 7
cadet alain
you want a range of udp ports to be published on the internet?
Then you can use the ACL with the range keyword as above but for udp
access-list 111 permit udp host 192.168.1.1 any range 2000 2100
call it inside a route-map like this:
route-map UDP_PORTS
match ip address 111
Then ip nat inside static route-map UDP_PORTS interface
Alain.
at least
ip nat inside static route-map UDP_PORTS poll IP
ip nat pool IP 1.1.1.1 1.1.1.1 netmask 255.255.255.252
this construction does'n work
Did you try the one I proposed?
Alain.
Yes,
but in my case global address on which clients comes from internet on udp ports (range udp 51000 54000) is secondary on interface
interface g0/1.300
ip address 1.1.1.2 255.255.255.0
ip address 1.1.1.1 255.255.255.0 secondary
ip nat inside static route-map UDP_PORTS interface g0/1.300
no translations in NAT table when someone come from internet to udp 1.1.1.1:52111
so replace the interface keyword with the secondary address and tell me if it works.
Alain.
XXX(config)#ip nat inside so route-map UDP_PORTS ?
  interface  Specify interface for global address
  pool       Name pool of global addresses
In my IOS it does't allow type IP(A.B.C.D) after route-map NAME, only pool NAME, and this I try, see my post #2 with pool
any ideas?
