Umbrella Portal AD Integration
Karthik_V
Can we integrate the Cisco Umbrella with AD for login to the umbrella portal as well for any reports, review and configuration purpose ???
No you cannot use AD for Umbrella login. You can either configure SAML (providers include PingID, Azure, Okta, Onelogin, Duo) or 2FA, support doc here provides more information.
