Unable to access internal web and exchange server from internet
alex.mastoris
Last time I worked with routers was some time ago and cant get my head around this. I recently purchased a Cisco 877 router and have my web server plugged directly into it. Clients are unable to access my web site nor send emails to me. I have tried port forwarding etc but nothing seems to work.
davidrawle
Exactly the same here... I will be watching this thread!
22 Replies 22
davidrawle
There are several things that you could tell us that would be very helpful in diagnosing this problem:
- if the web server is plugged directly into the router, can the web server communicate with the router (are there any cable issues, or speed/duplex issues)?
- can the router access Internet resources (ping or traceroute to http://www.cisco.com for example)? (are there any routing issues between the router and the service provider?)
- can the web server access Internet resources (ping or traceroute to http://www.cisco.com for example)? (is the server default-gateway correct? are addresses being translated properly? are there DNS issues?)
It would be helpful if you would post the configuration of the router.
If you can tell us these things we may be able to make progress in solving this issue.
Rick
Rick
Hi Rick, here is the config from my router.
Building configuration...
Current configuration : 3181 bytes
version 12.4
no service pad
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret *******
enable password *******
no aaa new-model
resource policy
clock timezone EST 10
clock summer-time EDT recurring last Sun Oct 2:00 last Sun Mar 2:00
ip subnet-zero
no ip source-route
ip cef
ip domain name <> (I also have another domain <> (How can I add this?))
ip name-server <>160.35
ip name-server <>160.36
ip name-server <>56.56
ip name-server <>184.150
ip name-server <>6.134
ip name-server <>219.3
username ******* privilege 15 password *******
interface ATM0
no ip address
ip nat outside
no ip virtual-reassembly
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 10.7.2.254 255.255.255.224
ip nat inside
ip tcp adjust-mss 1420
interface Dialer0
bandwidth 1500
ip address negotiated
ip access-group 101 out
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
ppp chap hostname *******@<>
ppp chap password *******
ppp pap sent-username *******@<>password *******
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 10.7.2.250 80 isp.static.ip 80 extendable
access-list 1 permit 10.7.2.0 0.0.0.255
access-list 10 permit 10.7.2.227
access-list 10 deny any
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq smtp
access-list 101 permit udp any any eq domain
access-list 101 permit udp any any eq ntp
access-list 101 deny ip any any
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
login local
line vty 0 4
access-class 10 in
login local
scheduler max-task-time 5000
ntp clock-period 17176872
ntp server <>160.2
end
Traceroute results from router:
Translating "<>"...domain server (<>160.35) (<>160.36) (2
08.76.56.56) (<>184.150) (<>6.134) (<>219.3)
% Unrecognized host or address.
Traceroute results from pc:
Tracing route to <> [<>.70]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms <> [10.7.2.254]
2 <> [10.7.2.254] reports: Destination net unreachable.
Trace complete.
nslookup results from pc:
nslookup <>
Server: <>.<>
Address: 10.7.2.250
Address: <>20.137
nslookup <>
Server: <>.<>
Address: 10.7.2.250
Non-authoritative answer:
Address: <>.70
Alexandros
Thank you for posting the router configuration. That does address my question about whether you were translating addresses. I see an ip nat outside on the ATM interface which I believe does not need to be there (but I do not believe that it hurts anything by being there). There is translation for the inside host addresses and there is a static translation for the server. I am not clear what the server address is translating to, but I assume that it is ok.
I am surprised that apparently the router is returning the error destination network is not available. Can you post the output of show ip route from the router?
Rick
Rick
Rick, Thanks for getting back to me on this. Here is the results for sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
203.219.20.0/32 is subnetted, 1 subnets
C 203.219.20.137 is directly connected, Dialer0
10.0.0.0/27 is subnetted, 1 subnets
C 10.7.2.224 is directly connected, Vlan1
202.7.162.0/32 is subnetted, 1 subnets
C 202.7.162.164 is directly connected, Dialer0
S* 0.0.0.0/0 is directly connected, Dialer
I also had the line of ip nat inside source static tcp 10.7.2.250 25 203.219.20.137 25 in the config as well which I had removed at the time of the config dump.
Alexandros
Thanks for posting the additional information. At this point I am wondering if the issue may be the access list 101 which is applied outbound on the dialer interface. It does not permit any traceroute traffic. Would you be able to open up that access list (at least for testing purposes) and see if the behavior changes?
Rick
Rick
Hi Alex,
Warning - I am all new to Cisco, so I may be misleading you more...
I had exactly the same problem but it is now fixed. I fiddled and fiddled and fiddled so not really sure how it got fixed.
My Dialer:
interface Dialer0
description $FW_OUTSIDE$
ip address 78.32.54.113 255.255.255.248
ip access-group 103 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect SDM_LOW out
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname dsl-login-string
ppp chap password 7 ******
It checks 103 in rather than out. I reasoned that it was traffic into the Dialer interface from the Internet that I wanted to check.
access-list 103 permit tcp any host 78.32.54.118 eq www
access-list 103 permit gre any any
access-list 103 permit ip any host 78.32.54.114
access-list 103 permit udp host 195.74.113.62 eq domain host 78.32.54.113
access-list 103 permit udp host 195.74.113.58 eq domain host 78.32.54.113
access-list 103 deny ip 192.168.7.0 0.0.0.255 any
access-list 103 permit icmp any host 78.32.54.113 echo-reply
access-list 103 permit icmp any host 78.32.54.113 time-exceeded
access-list 103 permit icmp any host 78.32.54.113 unreachable
access-list 103 permit tcp any host 78.32.54.113 eq 443
access-list 103 permit tcp any host 78.32.54.113 eq 22
access-list 103 permit tcp any host 78.32.54.113 eq cmd
access-list 103 deny ip 10.0.0.0 0.255.255.255 any
access-list 103 deny ip 172.16.0.0 0.15.255.255 any
access-list 103 deny ip 192.168.0.0 0.0.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip host 0.0.0.0 any
access-list 103 deny ip any any log
and finally
ip nat inside source static tcp 192.168.7.118 80 78.32.54.118 80 extendable
My www is actually available from outside. Trying to get there from inside my network doesn't work. I had to use my mobile to find out if 78.32.54.118 was open on port 80 and it was.
(You should be able to try it for real.)
Any help here?
David
David
Congratulations on getting yours working. And thanks for posting your config. In looking at it I see several differences which I do not believe are especially important (you have an input access list while Alexandros has only an output (and your SDM_LOW out gives you the outbound filtering) is structured differently, you turn off redirects, unreachables, and proxy-arp which he does not).
I do see what I believe is a critical difference. You specify ppp authentication chap callin. While he has several ppp chap parameters specified, he does not actually tell the interface to authenticate with chap. I believe that it is the fundamental problem (and may explain the network not reachable error - even though the routing table has the default route installed, the interface will not transmit traffic if it has not authenticated).
Alexandros I suggest that you add ppp authentication chap callin and see if it fixes your problem.
Rick
Rick
Hi Rick,
I know... it feels like I just scaled Everest :-)
I turned my ppp auth chap callin off and I could still get to the www.
Now the chap bit of my dialer just says:
dialer pool 1
dialer-group 1
no cdp enable
Would I need to bounce the line too? (how do I do that without a write mem & power cycling?)
David
David
Once the line is up and authenticated it should continue to work - which is what you are describing. I would guess that a shutdown and a no shutdown would effectively bounce the line and require the initialization process to authenticate. I would probably do the dialer and also the ATM interface.
Rick
Rick
Hi Rick,
I decided to temporarily redirect the phones and did a power cycle...
My Dialer now says:
interface Dialer0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp chap password 7 password
And I can still get to live www on 118 and 114 using my mobile internet, so I am guessing in my environment, at least, that the callin line isn't necessary. (I cannot see any difference in functionality at all.)
I am a real novice in IOS, but I read somewhere that if you had no ACL for incoming connections to an interface, there was an implicit 'deny ip any any' applied.
For that reason I have the BVI with an
ip access-group 100 in
access-list 100 deny ip 78.32.54.112 0.0.0.7 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
Or did I mis-understand.
I will be putting the line back, just in case though...
However, it gave a warning message.
gateway(config-if)#ppp authentication chap callin
AAA: Warning, authentication list "default" is not defined for PPP.
Just added
aaa authentication ppp default local
and the warning seemed to go away ;-)
David
David
Thanks for continuing to experiment and explore this issue.
My first thought is about your comment:
I am not sure where this is coming from, but in recent versions of IOS I do not believe that it is correct. In some (old) versions of IOS if there was an access-group configured on an interface and if there was no access-list corresponding to the access-group there was an implicit deny ip any any. But for quite a while the behavior has been that if there was an access-group on an interface and if there was no access-list then it effectively was ip permit any any.
My second thought is that you mention BVI. I am not sure if that is a mis-statement or not. There has not been any mention of BVI in this thread until this. If you do have a BVI then perhaps I should ask you to post the complete configuration of your router so that we can understand the complete context better.
Rick
Rick
Hi Rick,
Probably complete rubbish but it does seem to do what Alex wants...
David
