Unable to access NAT devices on Cisco 891F
jaydensanders
I was changing my configuration for my router and somehow messed up the NAT translation.  Previously it was working.  I should have made a backup config.  However, now I cannot access any devices on my internal network setup with NAT from the outside. I can't even SSH into the router remotely.  What would cause this?
Below is my config:
Building configuration...
Current configuration : 2775 bytes
! Last configuration change at 14:45:14 UTC Wed Mar 2 2016 by thatchercomp
version 15.3
hostname GCT890
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging buffered
no logging console
enable secret 5 $1$MPcW$z6ME5/8/0/GhvOx4hN55//
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
ip dhcp excluded-address 192.168.0.1 192.168.0.3
ip dhcp pool internal
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 8.8.8.8
ip name-server 24.116.0.53
ip name-server 24.116.2.50
ip cef
no ipv6 cef
license udi pid C891F-K9 sn FGL19402189
object-group network Server
host 192.168.0.4
username thatchercomp privilege 15 secret 5 $1$raU3$Wfq4vq/vZxOlzdOCAim/3.
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
switchport access vlan 2
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address (my public ip goes here) 255.255.255.192
ip nat outside
ip virtual-reassembly in
interface Vlan2
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface Async3
no ip address
encapsulation slip
ip default-gateway 72.24.66.193
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 101 interface Vlan1 overload
ip nat inside source static tcp 192.168.0.4 82 interface Vlan1 80
ip nat inside source static tcp 192.168.0.4 3389 interface Vlan1 3015
ip route 0.0.0.0 0.0.0.0 Vlan1
access-list 101 remark CCP_ACL Category=18
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
flowcontrol hardware
line vty 0 4
transport input telnet
scheduler allocate 20000 1000
end
Million thanks in advance,
Jayden
Shaunak
Please try the following changes on the device--
1. Enable SSH under the VTY lines only telnet is allowed right now
2. Exclusively deny the statically forwarded IP/Ports in the ACL used for NAT overload, 192.168.0.4 82 & 192.168.0.4 3389. The deny statements should be above the permit from internal subnet to all statement, this is a good practice to follow.
3. Configure SSH on the device, you would  need to configure the hostname, domain name, a local AAA record (already configured), generate the SSH RSA keys on the device and configure the ssh version on the device SSHv1 or SSHv2. A quick google search on how to configure SSH on IOS devices will give you good links and should be a good read.
Please revert on how these steps come along.
Shaunak
