Unable to access physical server on Ethernet but only through Wifi
dan wabwile
Hello team,
What could be the issue if i am able to access local servers on LAN through wifi but not accessible through Ethernet.
Both server and workstation/pc on domain are on the same subnet.
I am using the dhcp server for address lease and the server ip is reserved.
Dan Wabwile
IT Support
there is L2 issue,
if you use WLC then the WLC use tunnel and can override l2 issue.
check the L2
dan wabwile
Ok, am not using WLC let me check.
Am getting this fault on some devices but there's handshake between the physical servers and other devices on the network
Dan Wabwile
IT Support
  There are many reasons that could cause this scenario. For example,  you are passing through a router and the router does not have routes. Or the router has Access List. Or the configuration is not right.
 If you explain the environment would be easier to help. If this is  PacketTracer project, put it here.
