unable to boot from IOS on new ISR4221/K9 router, Router boots in RMON
rahul0006
i am deploying a new CISCO ISR4221/K9 router at customers place, i have unpacked a new router but the router is starting into ROMMON Mode, below is the message displayed on router, please help to resolve the issue:
Current Image running: Boot ROM0
% Failed to initialize NVRAM
% Failed to initialized Backup NVRAM
6 Replies 6
Leo Laohoo
If the router boots into ROMMON, post the complete output to the following commands:
  1. dir flash:
  2. set
PFB output:
Router#dir flash:
Directory of bootflash:/
322561 drwx 4096 Dec 6 2021 10:48:34 +00:00 .ssh
266113 drwx 4096 Dec 6 2021 10:50:43 +00:00 core
338689 drwx 4096 Dec 6 2021 10:48:40 +00:00 .prst_sync
306433 drwx 4096 Dec 6 2021 10:48:47 +00:00 .rollback_timer
161281 drwx 12288 Dec 6 2021 11:09:12 +00:00 tracelogs
80641 drwx 4096 Dec 6 2021 10:49:00 +00:00 .dbpersist
11 -rw- 20109 Dec 6 2021 10:49:10 +00:00 ios_core.p7b
225793 drwx 4096 Dec 6 2021 10:50:37 +00:00 onep
13 -rwx 26 Dec 6 2021 10:51:15 +00:00 .installer
12 -rw- 30 Dec 6 2021 11:05:32 +00:00 throughput_monitor_pa
rams
395137 drwx 4096 Dec 6 2021 10:50:42 +00:00 sdwan
18 -rw- 419430400 Dec 6 2021 11:08:37 +00:00 .sdwaninstallerfs
330625 drwx 4096 Dec 6 2021 10:50:43 +00:00 callhome
370945 drwx 1024 Dec 6 2021 10:51:15 +00:00 .sdwaninstaller
177409 drwx 4096 Dec 6 2021 10:51:16 +00:00 vmanage-admin
19 drwx 4096 Dec 6 2021 11:03:03 +00:00 lost+found
233858 -rw- 3 Nov 1 2021 04:25:56 +00:00 hugepage.conf
233860 -rw- 50164 Nov 1 2021 04:25:56 +00:00 isr4200-firmware_dre
amliner.16.10.3a.SPA.pkg
233861 -rw- 10703860 Nov 1 2021 04:25:56 +00:00 isr4200-firmware_ngw
ic_t1e1.16.10.3a.SPA.pkg
233862 -rw- 9241588 Nov 1 2021 04:25:56 +00:00 isr4200-firmware_nim
_async.16.10.3a.SPA.pkg
233863 -rw- 4604920 Nov 1 2021 04:25:56 +00:00 isr4200-firmware_nim
_bri_st_fw.16.10.3a.SPA.pkg
233864 -rw- 17490932 Nov 1 2021 04:25:56 +00:00 isr4200-firmware_nim
_cwan.16.10.3a.SPA.pkg
233865 -rw- 2520048 Nov 1 2021 04:25:56 +00:00 isr4200-firmware_nim
_ge.16.10.3a.SPA.pkg
233866 -rw- 11490292 Nov 1 2021 04:25:56 +00:00 isr4200-firmware_nim
_shdsl.16.10.3a.SPA.pkg
233867 -rw- 6304756 Nov 1 2021 04:25:56 +00:00 isr4200-firmware_nim
_xdsl.16.10.3a.SPA.pkg
233868 -rw- 10118128 Nov 1 2021 04:25:56 +00:00 isr4200-firmware_pri
nce.16.10.3a.SPA.pkg
233869 -rw- 348767228 Nov 1 2021 04:25:57 +00:00 isr4200-mono-ucmk9.1
6.10.3a.SPA.pkg
233870 -rw- 31244759 Nov 1 2021 04:27:00 +00:00 isr4200-rpboot.16.10
.3a.SPA.pkg
233859 -rw- 7905 Nov 1 2021 04:27:00 +00:00 packages.conf
20 -rw- 7905 Nov 1 2021 04:04:19 +00:00 prev_packages.conf
7194652672 bytes total (5956976640 bytes free)
Router#
2. SET
% incomplete command
regards
looks like there is no valid image ( a file that with a .bin extension) in your bootflash. The problem is: you cannot just download it from the Cisco website, you need a service contract for that.
Where did you get that router ?
Could solve the problem? failled to initialize NVRAM
I haven't still been able to Break into the router
Console into the router and reboot.
Dump the console output here.
Leo Laohoo
Router is meant to be SD-WAN.
