Rip v1 routing
maksunity
Hello, I have a network topology which will be shown below. Two routers R1 and R4 are connected via Serial ports. The routers will be configured below. My question is why when I build the routing table for R1 (show ip route), in the last two lines I have explicitly the subnet between the routers (10.70.0.2/16) and the port of router R4 (10.70.0.2/32). In all similar cases of connecting two routers via serial ports, this is not the case.
Example show ip route:
r1.lab#show ip route
Codes: C – connected, S – static, R – RIP, M – mobile, B – BGP
10.0.0.0/8 is variably subnetted, 8 subnets, 2 masks
C 10.10.0.0/16 is directly connected, FastEthernet0/0
R 10.30.0.0/16 [120/1] via 10.20.0.2, 00:00:19,FastEthernet0/1
C 10.20.0.0/16 is directly connected, FastEthernet0/1
R 10.40.0.0/16 [120/1] via 10.70.0.2, 00:00:14, Serial0/1/0
R 10.60.0.0/16 [120/2] via 10.70.0.2, 00:00:14,
Serial0/1/0
R 10.50.0.0/16 [120/1] via 10.70.0.2, 00:00:14, Serial0/1/0
C 10.70.0.0/16 is directly connected, Serial0/1/0
C 10.70.0.2/32 is directly connected, Serial0/1/0
Network topology
Router settings static routing:
R1:
r1.lab#conf t
r1.lab(config)#username r4 privilege 0 password 0 pass
r1.lab(config)#interface FastEthernet0/0
r1.lab(config-if)# ip address 10.10.0.1 255.255.0.0
r1.lab(config-if)# duplex auto
r1.lab(config-if)# speed auto
r1.lab(config-if)#!
r1.lab(config-if)#interface FastEthernet0/1
r1.lab(config-if)# ip address 10.20.0.1 255.255.0.0
r1.lab(config-if)#!
r1.lab(config-if)#interface Serial0/1/0
r1.lab(config-if)# ip address 10.70.0.1 255.255.0.0
r1.lab(config-if)# encapsulation ppp
r1.lab(config-if)# ppp authentication chap
r1.lab(config-if)# ppp chap hostname r1
r1.lab(config-if)# ppp chap password 0 pass
R2:
r2.lab#conf t
r2.lab(config)#interface FastEthernet0/0
r2.lab(config-if)# ip address 10.30.0.1 255.255.0.0
r2.lab(config-if)# duplex auto
r2.lab(config-if)# speed auto
r2.lab(config-if)#!
r2.lab(config-if)#interface FastEthernet0/1
r2.lab(config-if)# ip address 10.20.0.2 255.255.0.0
R3:
r3.lab#conf t
r3.lab(config)#interface FastEthernet0/0
r3.lab(config-if)# ip address 10.60.0.1 255.255.0.0
r3.lab(config-if)# duplex auto
r3.lab(config-if)# speed auto
r3.lab(config-if)#!
r3.lab(config-if)#interface FastEthernet0/1
r3.lab(config-if)# ip address 10.50.0.2 255.255.0.0
R4:
r4.lab#conf t
r4.lab(config)#username r1 privilege 0 password 0 pass
r4.lab(config)#interface FastEthernet0/0
r4.lab(config-if)# ip address 10.40.0.1 255.255.0.0
r4.lab(config-if)# duplex auto
r4.lab(config-if)# speed auto
r4.lab(config-if)#!
r4.lab(config-if)#interface FastEthernet0/1
r4.lab(config-if)# ip address 10.50.0.1 255.255.0.0
r4.lab(config-if)#!
r4.lab(config-if)#interface Serial0/1/0
r4.lab(config-if)# ip address 10.70.0.2 255.255.0.0
r4.lab(config-if)# encapsulation ppp
r4.lab(config-if)# clock rate 128000
r4.lab(config-if)# ppp authentication chap
r4.lab(config-if)# ppp chap hostname r4
r4.lab(config-if)# ppp chap password 0 pass
r4.lab(config-if)#clock rate 128000
Configuring RIP v1 on routers:
R1:
r1.lab#conf t
r1.lab(config)#router rip
r1.lab(config-router)#version 1
r1.lab(config-router)#network 10.10.0.0
r1.lab(config-router)#network 10.20.0.0
r1.lab(config-router)#network 10.70.0.0
R2:
r2.lab#conf t
r2.lab(config)#router rip
r2.lab(config-router)#version 1
r2.lab(config-router)#network 10.30.0.0
r2.lab(config-router)#network 10.20.0.0
R3:
r3.lab#conf t
r3.lab(config)#router rip
r3.lab(config-router)#version 1
r3.lab(config-router)#network 10.60.0.0
r3.lab(config-router)#network 10.50.0.0
R4:
r4.lab#conf t
r4.lab(config)#router rip
r4.lab(config-router)#version 1
r4.lab(config-router)#network 10.40.0.0
r4.lab(config-router)#network 10.50.0.0
r4.lab(config-router)#network 10.70.0.0
Thanks in advance!
25 Replies 25
Joseph W. Doherty
Did you also use PPP encapsulation for your other serial links (that showed differently for networks)?
I have configured the IP addresses and subnet mask on the Fast Ethernet interfaces. On the Serial interfaces I configured PPP encapsulation with CHAP authorization protocol and Pass password according to the topology
This normal
Any p2p interface will appear as two
"C" which is subnet of interface as you enter under the interface
"L"  the /32 ip of interface.
The router use longest match so always it use /32 but for IGP it adverise /16 (in your case)
MHM
These last two lines in the routing tables with explicitly specified local network and router port are found in all router routing tables (I'll give them below).
r2.lab#show ip route
R 0.10.0.0/16 [120/1] via 10.20.0.1, 00:00:13,
FastEthernet0/1
C 10.30.0.0/16 is directly connected, FastEthernet0/0
R 10.40.0.0/16 [120/2] via 10.20.0.1, 00:00:13,
FastEthernet0/1
R 10.60.0.0/16 [120/3] via 10.20.0.1, 00:00:13,
FastEthernet0/1
R 10.50.0.0/16 [120/2] via 10.20.0.1, 00:00:13,
FastEthernet0/1
R 10.70.0.0/16 [120/1] via 10.20.0.1, 00:00:13,
FastEthernet0/1
R 10.70.0.2/32 [120/1] via 10.20.0.1, 00:00:13,
FastEthernet0/1
R3:
r3.lab#show ip route
R 10.10.0.0/16 [120/2] via 10.50.0.1, 00:00:00,
FastEthernet0/1
R 10.30.0.0/16 [120/3] via 10.50.0.1, 00:00:00,
FastEthernet0/1
R 10.20.0.0/16 [120/2] via 10.50.0.1, 00:00:00,
FastEthernet0/1
R 10.40.0.0/16 [120/1] via 10.50.0.1, 00:00:00,
FastEthernet0/1
C 10.60.0.0/16 is directly connected, FastEthernet0/0
C 10.50.0.0/16 is directly connected, FastEthernet0/1
R 10.70.0.0/16 [120/1] via 10.50.0.1, 00:00:00,
FastEthernet0/1
R 10.70.0.1/32 [120/1] via 10.50.0.1, 00:00:00,
FastEthernet0/1
R4:
r4.lab#show ip route
masks
R 10.10.0.0/16 [120/1] via 10.70.0.1, 00:00:22, Serial0/1/0
R 10.30.0.0/16 [120/2] via 10.70.0.1, 00:00:22,
Serial0/1/0
R 10.20.0.0/16 [120/1] via 10.70.0.1, 00:00:22,
Serial0/1/0
C 10.40.0.0/16 is directly connected, FastEthernet0/0
R 10.60.0.0/16 [120/1] via 10.50.0.2, 00:00:16,
FastEthernet0/1
C 10.70.0.1/32 is directly connected, Serial0/1/0
I apologize if I explain something wrong, I study at the university and my supervisor after configuring this network in the classroom on a given topology requires an explanation from the official documentation Cisco, but there I did not find explanations so I turned here
you are correct,
can you change the ver to 2 and check the route in R2 and R3
This is my new topology
R1:
r1.lab#conf t
r1.lab(config-router)#version 2
R2:
r2.lab#conf t
r2.lab(config-router)#version 2
R3:
r3.lab#conf t
r3.lab(config-router)#version 2
R4:
r4.lab#conf t
r4.lab(config-router)#version 2
New show ip route:
R1:
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
R 10.0.0.0/8 [120/1] via 192.168.100.2, 00:00:11,
Serial0/1/0
R 10.30.0.0/16 [120/1] via 10.20.0.2, 00:00:08,
FastEthernet0/1
192.168.100.0/24 is variably subnetted, 2 subnets,
2 masks
C 192.168.100.0/30 is directly connected, Serial0/1/0
C 192.168.100.2/32 is directly connected, Serial0/1/0
R2:
R 10.10.0.0/16 [120/1] via 10.20.0.1, 00:00:20,
FastEthernet0/1
R 10.0.0.0/8 [120/2] via 10.20.0.1, 00:00:20,
FastEthernet0/1
R 192.168.100.0/24 [120/1] via 10.20.0.1, 00:00:20,
FastEthernet0/1
R3:
R 10.0.0.0/8 [120/2] via 10.50.0.1, 00:00:24,
FastEthernet0/1
R 10.40.0.0/16 [120/1] via 10.50.0.1, 00:00:24,
FastEthernet0/1
R 192.168.100.0/24 [120/1] via 10.50.0.1, 00:00:24,
FastEthernet0/1
R4:
R 10.0.0.0/8 [120/1] via 192.168.100.1, 00:00:06,
Serial0/1/0
R 10.60.0.0/16 [120/1] via 10.50.0.2, 00:00:09,
FastEthernet0/1
2 masks
C 192.168.100.1/32 is directly connected, Serial0/1/0
First rip is no more use' but since you study it I will try help you as I can.
Now
You change serial interface to be 192.x.x.x this without use no-autosummary under rip make another issue called discontiguous issue.
So only add no auto-summary under rip and check.
MHM
Oh my, I suspect bringing up discontinuous Classful subnets is very likely to confuse OP.  Plus, are you suggesting to use a Class C network with a Class A mask?
So, do I now understand all you serial ports were configured the same and they all impacted the route table in a similar manner, correct?
Possibly you're wondering why the serial ports impact the route table differently from the Ethernet ports?  If so, Ethernet ports are considered multi-access while serial ports are considered point-to-point.
Yes, the question is why Serial and Fe ports have different subnet mapping. The Fe port has only the subnet and nexthop explicitly listed, while the Serial port has both the subnet and the port of another router. And I would like to know why, because my job requires it. That is, why when building a routing table for the first router, for example, we see not:
C 10.20.0.0.0/16 is directly connected, FastEthernet0/1
C 10.70.0.0.0/16 is directly connected, Serial0/1/0
And we see:
C 10.70.0.0.2/32 is directly connected, Serial0/1/0
Why instead of one line for Fe ports we get two lines for Serial port.
That question was answered by myself and @MHM Cisco World, i.e. different kinds of interfaces.
I recall (?) you'll see a /32 and interface network for a loopback interface too.
If you were using OSPF, you would see it also treat, by default, Ethernet interfaces differently from serial interfaces.
Lastly, and BTW, the connected "C" routes are independent of the IGP, whether RIP or another.  However, RIP(v1) is a Classful routing protocol that has its own issues, such as the /32 IPs will not be seen by other RIP routers.
Blue_Bird
Hi maksunity,
This topology is an example of classless...so, you should use RIP version 2 with no auto-summary command...
Please try...following configuration...( accroding to new topology)
r1.lab#conf t
r1.lab(config-router)# network 10.20.0.0
r1.lab(config-router)# network 192.168.100.0
r1.lab(config-router)# network 10.10.0.0
r1.lab(config-router)# no auto-summary
r1.lab(config-router)#end
r2.lab#conf t
r2.lab(config-router)# network 10.20.0.0
r2.lab(config-router)# network 10.30.0.0
r2.lab(config-router)# no auto-summary
r2.lab(config-router)# end
Same way...configure for other routers...
Best regards
******* If This Helps, Please Rate *******
I've disabled autosummarization for RIPv2:
R1:
r1.lab#conf t
R2:
r2.lab#conf t
R3:
r3.lab#conf t
r3.lab(config-router)# no auto-summary
R4:
r4.lab#conf t
r4.lab(config-router)# no auto-summary
This is what I got:
10.0.0.0/8 is variably subnetted, 7 subnets, 2 masks
R 10.0.0.0/8 [120/1] via 192.168.100.2, 00:01:24,
Serial0/1/0
R 10.30.0.0/16 [120/1] via 10.20.0.2, 00:00:28,
FastEthernet0/1
R 10.40.0.0/16 [120/1] via 192.168.100.2, 00:00:24,
Serial0/1/0
R 10.60.0.0/16 [120/2] via 192.168.100.2, 00:00:24,
Serial0/1/0
R 10.50.0.0/16 [120/1] via 192.168.100.2, 00:00:24,
Serial0/1/0
2 masks
R2:
10.0.0.0/16 is subnetted, 6 subnets
R 10.10.0.0 [120/1] via 10.20.0.1, 00:00:22,
FastEthernet0/1
C 10.30.0.0 is directly connected, FastEthernet0/0
C 10.20.0.0 is directly connected, FastEthernet0/1
R 10.40.0.0 [120/2] via 10.20.0.1, 00:00:22,
FastEthernet0/1
R 10.60.0.0 [120/3] via 10.20.0.1, 00:00:22,
FastEthernet0/1
R 10.50.0.0 [120/2] via 10.20.0.1, 00:00:22,
FastEthernet0/1
192.168.100.0/24 is variably subnetted, 3 subnets,
3 masks
R 192.168.100.0/30 [120/1] via 10.20.0.1, 00:00:22,
FastEthernet0/1
R 192.168.100.0/24 is possibly down,
routing via 10.20.0.1, FastEthernet0/1
R 192.168.100.2/32 [120/1] via 10.20.0.1, 00:00:22,
FastEthernet0/1
R3:
R 10.10.0.0 [120/2] via 10.50.0.1, 00:00:22,
FastEthernet0/1
R 10.30.0.0 [120/3] via 10.50.0.1, 00:00:22,
FastEthernet0/1
R 10.20.0.0 [120/2] via 10.50.0.1, 00:00:22,
FastEthernet0/1
R 10.40.0.0 [120/1] via 10.50.0.1, 00:00:22,
FastEthernet0/1
C 10.60.0.0 is directly connected, FastEthernet0/0
C 10.50.0.0 is directly connected, FastEthernet0/1
3 masks
R 192.168.100.0/30 [120/1] via 10.50.0.1, 00:00:22,
FastEthernet0/1
routing via 10.50.0.1, FastEthernet0/1
R 192.168.100.1/32 [120/1] via 10.50.0.1, 00:00:22,
FastEthernet0/1
R4:
R 10.10.0.0/16 [120/1] via 192.168.100.1, 00:00:09,
Serial0/1/0
R 10.0.0.0/8 is possibly down,routing via
192.168.100.1, Serial0/1/0
R 10.30.0.0/16 [120/2] via 192.168.100.1, 00:00:09,
Serial0/1/0
R 10.20.0.0/16 [120/1] via 192.168.100.1, 00:00:09,
Serial0/1/0
R 10.60.0.0/16 [120/1] via 10.50.0.2, 00:00:07,
FastEthernet0/1
2 masks
Screenshot (614).pngScreenshot (615).pngScreenshot (616).pngScreenshot (617).pngScreenshot (618).png
