Unable to failover Internet routers
Hi all,
We have two internet connections in our org. One for Primary and the other for secondary. Both from different ISP's. When we tried to do a failover test, the traffic is unable to shift to secondary internet. we found the trace to be reaching until secondary internet router. We configured BGP path prepend in secondary and HSRP is run between two routers. We tried connecting a laptop to the WAN internface of the ISP and assigned the ISP's IP to the laptop and internet seems to be working fine in laptop. But when we tried connecting the same Laptop to LAN interface and assign our APNIC IP's to the laptop we are unable to browse the internet.
Can any one please help on this.............
amabdelh
Can you provide your configuration on both routers and show logs, bgp summary, interfaces
I suspect the issue is with the nat, so you my also need to enable nat debugs
