unable to internet access from R69 routers
R Manjunatha
Level 3
Level 3
I can ping the DNS 8.8.8.8 from the R54 Router and, similarly, can't ping the same from the R69 Router. my home router Gateway is 192.168.29.1.
R54 Router
R54#ping 192.168.29.1
Sending 5, 100-byte ICMP Echos to 192.168.29.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
R54#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 9/10/14 ms
R54#sh run
Building configuration...
Current configuration : 2252 bytes
! No configuration change since last restart
! NVRAM config last updated at 15:24:56 UTC Mon Sep 11 2023
version 15.7
hostname R54
boot-start-marker
boot-end-marker
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
interface Loopback0
ip address 54.54.54.54 255.255.255.255
interface Loopback1
ip address 10.10.1.1 255.255.255.0
interface Loopback2
ip address 10.10.2.1 255.255.255.0
interface Loopback3
ip address 10.10.3.1 255.255.255.0
interface Loopback4
ip address 10.10.4.1 255.255.255.0
interface Loopback5
ip address 10.20.1.1 255.255.255.0
interface Loopback6
ip address 10.20.2.1 255.255.255.0
interface Loopback7
ip address 10.20.3.1 255.255.255.0
interface Loopback8
ip address 10.20.4.1 255.255.255.0
interface Ethernet0/0
ip address 172.16.40.2 255.255.255.252
duplex auto
interface Ethernet0/1
ip address 172.16.60.2 255.255.255.252
duplex auto
interface Ethernet0/2
ip address dhcp
duplex auto
interface Ethernet0/3
no ip address
shutdown
duplex auto
router bgp 400
bgp log-neighbor-changes
network 10.10.1.0 mask 255.255.255.0
network 10.10.2.0 mask 255.255.255.0
network 10.10.3.0 mask 255.255.255.0
network 10.10.4.0 mask 255.255.255.0
network 10.20.1.0 mask 255.255.255.0
network 10.20.2.0 mask 255.255.255.0
network 10.20.3.0 mask 255.255.255.0
network 10.20.4.0 mask 255.255.255.0
network 54.54.54.54 mask 255.255.255.255
network 192.168.29.0
redistribute connected
redistribute static
neighbor 172.16.40.1 remote-as 200
neighbor 172.16.40.1 next-hop-self
neighbor 172.16.60.1 remote-as 300
neighbor 172.16.60.1 next-hop-self
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.29.1
line con 0
logging synchronous
line aux 0
line vty 0 4
login
transport input none
ntp server 34.202.215.187
ntp server pool.ntp.org
end
R69 Router
R69#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 14 subnets, 2 masks
B 10.10.1.0/24 [20/0] via 69.69.69.1, 03:13:52
B 10.10.2.0/24 [20/0] via 69.69.69.1, 03:13:52
B 10.10.3.0/24 [20/0] via 69.69.69.1, 03:13:52
B 10.10.4.0/24 [20/0] via 69.69.69.1, 03:13:52
B 10.20.1.0/24 [20/0] via 69.69.69.1, 03:13:52
B 10.20.2.0/24 [20/0] via 69.69.69.1, 03:13:52
B 10.20.3.0/24 [20/0] via 69.69.69.1, 03:13:52
B 10.20.4.0/24 [20/0] via 69.69.69.1, 03:13:52
B 10.30.1.0/30 [20/0] via 69.69.69.1, 03:13:52
B 10.30.1.4/30 [20/0] via 69.69.69.1, 03:13:52
B 10.30.1.8/30 [20/0] via 69.69.69.1, 03:13:52
B 10.30.1.32/30 [20/0] via 69.69.69.1, 03:13:52
B 10.30.1.36/30 [20/0] via 69.69.69.1, 03:13:52
B 10.30.1.40/30 [20/0] via 69.69.69.1, 03:13:52
52.0.0.0/32 is subnetted, 1 subnets
B 52.52.52.52 [20/0] via 69.69.69.1, 03:13:52
54.0.0.0/32 is subnetted, 1 subnets
B 54.54.54.54 [20/0] via 69.69.69.1, 03:13:52
59.0.0.0/30 is subnetted, 1 subnets
B 59.59.59.0 [20/0] via 69.69.69.1, 03:13:52
69.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C 69.60.60.60/32 is directly connected, Loopback0
C 69.69.69.0/30 is directly connected, Ethernet0/1
L 69.69.69.2/32 is directly connected, Ethernet0/1
70.0.0.0/30 is subnetted, 1 subnets
B 70.70.70.0 [20/0] via 69.69.69.1, 03:13:52
76.0.0.0/30 is subnetted, 1 subnets
B 76.76.76.0 [20/0] via 69.69.69.1, 03:13:52
80.0.0.0/30 is subnetted, 1 subnets
B 80.80.80.0 [20/0] via 69.69.69.1, 03:13:52
86.0.0.0/30 is subnetted, 1 subnets
B 86.86.86.0 [20/0] via 69.69.69.1, 03:13:52
96.0.0.0/30 is subnetted, 1 subnets
B 96.96.96.0 [20/0] via 69.69.69.1, 03:13:52
172.16.0.0/30 is subnetted, 4 subnets
B 172.16.30.0 [20/0] via 69.69.69.1, 03:13:52
B 172.16.40.0 [20/0] via 69.69.69.1, 03:13:52
B 172.16.50.0 [20/0] via 69.69.69.1, 03:13:52
B 172.16.60.0 [20/0] via 69.69.69.1, 03:13:52
B 192.168.29.0/24 [20/0] via 69.69.69.1, 03:13:52
CE-10#ping 192.168.29.57
Sending 5, 100-byte ICMP Echos to 192.168.29.57, timeout is 2 seconds:
CE-10#ping 192.168.29.1
Success rate is 0 percent (0/5)
CE-10#ping 8.8.8.8
6 Replies 6
M02@rt37
Hello @R Manjunatha,
Where is CE-10 on your draw?
Do you test ping from CE-10 with source IP address ?
Best regards
R69 is the CE-10 Router in the Diagram and I tried with a source IP address.
Thanks for that clarification.
From R54 you ping you home router (.1) because R54 is directly connected to this home router with an interface in this range 192.168.29.0/24.
From R69 you ping 192.168.29.57, but ping failed to 192.168.29.1...this due to routing from your home router.
Does Home router has got IP route (static?) towards R69 ip 69.69.69.2 ?
Best regards
No static IP route towards R69 IP 69.69.69.2. let me try this once.
Yes. I can be able to ping my home router gateway 192.168.29.1 but I could not be able to reach internet DNS 8.8.8.8
OK @R Manjunatha
First step OK.
On CE-10 i dont see specific route towards 8 8.8.8.... thats the issue.
Best regards
