Unable to login to router
Raja_D
I have an issue noticed where I am able to login to a router from my hub router using one wan link ip address but not with other. Whenever I try to attempt login I get message as "Connection to x.x.x.x aborted: error status 32]". we have an acl configured on the line vty and there is nothing blocked in specific. Need your advise..
Both wan links are up and reacheable in network.
x.x.x.x is relating to ip ...
Mark Malone
seeing some relevant config here would help to see what way its setup , off my head check there is enough sessions available for a new connection in vty
also did you check the acl on both routers as your going out from one and into another
