Unable to Ping another network via router
angadmanroy
I was trying to create 2 networks (with N/w IDs -> 192.168.1.0 and 192.168.2.0), followed by joining these two via a router in cisco packet tracer. Now, I have assigned ips 192.168.x.i (x = 1,2 ; i = 1,2,3 i.e. 2 networks with 3 devices each). I even configured the router interfaces g0/0/0 and g0/0/1 but somehow am still unable to ping pcs in the other network.
I have attached images of the network layout and status of the pc, switches and router below.
May someone please point out what am I missing exactly?
balaji.bandi
From PC 192.168.1.2 can able to ping 192.168.1.1 ?
From PC 192.168.2.2 can able to ping 192.168.2.1 ?
YES - then check PC has any FW ?
Also check on router are you able to see show IP arp all the IP of PC ?
check IP routing enabled on  router (most new router should be enabled default)
still not working
show run from Router and switch will be helpfull.
BB
Tried to ping 192.168.1.1 (default gateway) from 192.168.1.2 but neither am I able to ping nor is the request getting timed out.
post below as requested information :
show run from Router and switch will be helpful.
BB
Martin L
You can attach your PT file here (must be in a zip format).
Regards, ML
**Please Rate All Helpful Responses **
