12-08-2016 09:23 AM - edited 03-05-2019 07:38 AM
The new switch I received has Firmware 1.3.0.62 (active image). Boot Version 1.1.0.6. I download the SX200_fw-14502.ros file.
I copied the file to the Desktop (windows 95), using IE6.
Logged into the switch and select upgrade firmware. Prompts form Method, I select http/https, then I select the path where the file exists. Select
(defaults are via http/https), Upgrade, Firmware Image) then Filename (Browswe to Desktop where file is located), hit apply, ok, Ok, then it fails with
Bytes transferred 0
Status: Copy Failed
Error Message: Copy illegal software format.
12-08-2016 10:55 PM
You will have to update the firmware to 1.3.5.x and the boot file to 1.3.5.06 before updating to 1.4.x, as stated in the release notes (available here).
12-09-2016 07:47 AM
Sent Too Soon...Please ignore. for some reason the 1.3.5.28 shows up to day. Thank you.
