Unable to use PIX 501 PDM
nicolas.guyot
i am trying to setup an old PIX501. I had reset password, restored to factory settings.
I am able to go to https://192.168.1.1 but when popup open it loads a moment and nothing happens.
I tried it from W7, W XP but still nothing happens
Can you help me ?
11 Replies 11
John Blakley
Do you have a console cable to get into it locally?
HTH, John *** Please rate all useful posts ***
Yes, i used It to reset password and restore to factory settings successfuly.
Can you post your pdm config and sh flash?
ok,
can you tell me how i can do it ?
thank you
sh conf
: Saved
: Written by enable_15 at 14:36:20.577 UTC Mon Feb 27 2012
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pixfirewall
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:3c000401612875053b7970b424c72912
Can you post "sh flash" or "dir"?
pixfirewall# sh flash
flash file system:  version:3  magic:0x12345679
  file 0: origin:       0 length:1978424
  file 1: origin: 2097152 length:1900
  file 2: origin: 2228224 length:3540
  file 3: origin: 2359296 length:3152452
  file 4: origin:       0 length:0
  file 5: origin: 7864320 length:308
hmmm...that didn't help much...what about a dir?
Otherwise, I reread your OP. If you're getting to the point of the PDM loading, it's probably not a problem of you not having the files on the box. You would simply not get connected or get a denial. If you're seeing it load, but nothing happens, the most common problem is the java version that you're running on your box. Unfortunately, I can't tell you what versions are good or bad...it's sometimes just a luck of the draw. Do you have other boxes that you could try? I also seem to remember that there was a way of controlling who could run the PDM. Try this:
config t
pixfirewall (config) # pdm ?
Can you post the results of this?
pixfirewall(config)# pdm ?
Usage:  pdm disconnect
        pdm history enable
        pdm logging [ []]
        pdm location
        pdm group
        pdm group reference
        show pdm history [view {all|12h|5d|60m|10m}] [snapshot]
                [feature {all|blocks|cpu|failover|ids|interface |
                memory|perfmon|sas|tunnels|xlates}] [pdmclient]
        show pdm logging
        show pdm sessions
        clear pdm [location|group|logging]
thank you for your help !
you should be right with java version problem.
i will try to install very old version and test it
Ok, it needs Java 5 to work
Thank you for your help
Glad to hear it...
Please rate all helpful posts...
