Understanding Async port operation
wilson_1234
We have a router with an HWIC-16A installed and using it for a terminal server.
All of the ports are configured as shown below. The port shown below has a console cable attached and is working when we reverse telnet from the router.
My question, is, is it normal for the port to be in "administratively down" condition?
If so, why does it default to that condition as my understanding was only a manual interaction could remote the "shutdown" statement from the interface.
sh int async 0/3/0
Async0/3/0 is administratively down, line protocol is down
Hardware is HWIC-Serial
MTU 1500 bytes, BW 9 Kbit/sec, DLY 100000 usec,
Encapsulation SLIP, loopback not set
Keepalive not set
DTR is pulsed for 5 seconds on reset
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/10 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
0 unknown protocol drops
0 carrier transitions
DCD=up DSR=up DTR=down RTS=down CTS=down
interface Async0/3/0
no ip address
encapsulation slip
shutdown
end
Async0/3/0 unassigned YES unset administratively down down
not sure I understand the question: the lines work, but one of them is 'shut' ? Can you post the full configuration of your terminal server ?
I agree with Georg that the question is not clear. I have two points that I hope might be helpful. There are some devices with interfaces that default to starting in the shutdown state. Not sure if this is one of these. Second point - I have seen some situations where interactions on a router to some error conditions will put the interface into the shutdown state with no manual intervention required. Not sure is this is one of those.
Third point - are you sure that someone did not issue the shutdown command on this interface?
Rick
Rick
