undocumented router command?
Erik Molenaar
Does anyone know the meaning and syntax of the command "logging queue-limit ..."?
I find it everywhere on cco in configurations but no in command references. Still it exists in IOS.
Even the command lookup tool says:
Tools & Resources
Command Lookup Tool
Not Found
The command 'logging queue-limit' was not found in the Cisco Command Reference
Erik
d.wingert
Hello Erik,
afaik, the command "logging queue-limit 100" would limit the queue in memory for logging messages that the router still has to write to the logging buffer and / or the console to 100. It's used to prevent that the router crashes or runs into processing problems due to an excessive load generated by to many logging messages.
Regards, Dirk.
