Unexpected Default Route Change with New SVI Configuration
Hi everyone,
I encountered a strange situation and could use some insights. Initially, I had the following setup:
- **Interface**: VLAN 200
- **Static IP Address**: 172.16.16.12
- **Static Route**:
ip route 0.0.0.0 0.0.0.0 172.16.16.245
Running `show ip route` gave me:
Gateway of last resort is 172.16.16.245 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 172.16.16.245
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.16.16.0/24 is directly connected, Vlan200
L 172.16.16.12/32 is directly connected, Vlan200
However, after adding a second SVI on VLAN 71 with the command `ip address dhcp`, the routing table changed to:
S* 0.0.0.0/0 [0/0] via 192.168.71.1
192.168.71.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.71.0/24 is directly connected, Vlan71
L 192.168.71.100/32 is directly connected, Vlan71
My question is: Why did the switch set `S* 0.0.0.0/0 [0/0] via 192.168.71.1` as the default route in the routing table and categorize it as static?
Any ideas or explanations would be greatly appreciated.
Thanks!
because the DHCP provide IP to VLAN is also push default route and SW prefer it
to solve this use in global mode
ip dhcp-client default-route distance 100 <<- this make distance of any default route get via DHCP have value 100 and hence make SW prefer the lowest metric one
MHM
