Upgrade isr4331 rommon and IOS
marzi
Hi all
I've to upgrade two ISR4331/K9 from IOS 03.16.04b (rommon 15.5(3)S4b) to IOS Cupertino-17.9.3a (rommon 16.12(2r)).
The first action that I will do will be the upgrade of the rommon and than the IOS-XE.
Reading the content of the following link,
https://www.cisco.com/c/en/us/td/docs/routers/access/isr4400/software/configuration/xe-17/isr4400-sw-config-xe-17/install.html#concept_AE015B14DA464F3C9F11AA887371C9F3
there's a note :
When you upgrade from Cisco IOS XE 3.x to 16.x image, you should first upgrade the rommon release to the 16.7(5r) rommon release.
After upgrading to the 16.7(5r) rommon release, based on the IOS XE 16.x image, the rommon release can be auto-upgraded to a later rommon release.
My question is :
Upgrade from 3.x to 16.x is a necessary intermediate step or is it possible to jump directly from 3.x to 17.9.3 ?
(obvously after the rommon upgrade from 15.5(3)S4b to 16.12(2r))
Thanks in advance
Fabrizio
2 Accepted Solutions
M02@rt37
Hello @marzi,
Dirte upgrade from 3.x.x to 17.9.x is supported.
FYI: https://community.cisco.com/t5/networking-knowledge-base/cisco-isr-amp-asr-1k-routers-ios-xe-firmware-upgrade-install/ta-p/4426457
Best regards
M02@rt37
Hello @marzi,
Best regards
