Upgraded ROMMON image failed verification check on ISR 4331
eric.yang
Hi there,
I tried to upgrade ROMMON firmware from 16.9(1r) to 16.12(2r) on an ISR4331 this morning, but I got the error "Upgraded ROMMON image failed verification check".  Is there any workaround to fix the issue? Thanks
ISR1#upgrade rom-monitor filename bootflash:isr4200_4300_rommon_1612_2r_SPA.pkg r0
Chassis model ISR4331/K9 has a single rom-monitor.
Upgrade rom-monitor
Target copying rom-monitor image file
Booted : 0
Selected : 0
Reset Reason: 0
Switching to ROM 1
Upgrading ROMMON image...
4194304+0 records in
4194304+0 records out
4194304 bytes (4.2 MB, 4.0 MiB) copied, 65.3277 s, 64.2 kB/s
4194304 bytes (4.2 MB, 4.0 MiB) copied, 32.5454 s, 129 kB/s
Verifying ROMMON image...
4194304 bytes (4.2 MB, 4.0 MiB) copied, 30.2041 s, 139 kB/s
Switching back to ROM 0
FAILURE: Upgraded ROMMON image failed verification check.
Upgrade image MD5 signature is 871f9d7df678f0c4ea92b7c9c4dfa88c
Upgraded ROMMON image MD5 signature is fd947e2a5f77be3c0989cd93f1cbb624
9 Replies 9
eric.yang
Find the solution at https://community.cisco.com/t5/cisco-software-discussions/isr4431-rommon-upgrade/td-p/4045424. Looks it only worked on IOS 9.16.09.05.
eric.yang
Any other idea/workaround? Nobody is in this branch office just in case if there is any issue during the upgrade.
The ROMMON firmware is corrupt.  Re-Download the firmware again from the Cisco website and compare the MD5 before continuing.
There was no issue with the Rommon file itself. The MD5 value is the same as the Cisco website.
Post the complete output to the command "verify /md5 bootflash:isr4200_4300_rommon_1612_2r_SPA.pkg ff042bf918b0088e913de0c1c23fa891".
It could be a defect a bug.
ISR1#verify /md5 isr4200_4300_rommon_1612_2r_SPA.pkg
.............................................................................Done!
verify /md5 (bootflash:isr4200_4300_rommon_1612_2r_SPA.pkg) = ff042bf918b0088e913de0c1c23fa891
I have never seen anything like it.
Raise a TAC Case.
eric.yang
I have upgraded the ROMMON firmware from 16.9(1r) to 16.12(2r) successfully on IOS 9.16.09.05. Please see ROMMON Compatibility Matrix at https://www.cisco.com/c/en/us/td/docs/routers/access/4400/cpld/isr4400_hwfp.html#pgfId-1077103
The ROMMON release 16.9(1r) is the first release that supports the Cisco BIOS Protection. After a device is upgraded to the 16.9(1r) ROMMON release, the ROMMON release cannot be downgraded to a release earlier than 16.9(1r). All future ROMMON releases can be downgraded to the 16.9(1r) release. Also, if a platform has a 16.9(1r) or later release installed, an IOS XE 16.9.1 or later release, or a SD-WAN 16.11.1 or later release must be used for the upgrade.
Thanks.  That is an interesting combo.  It now boils to the question:  Which comes first, the chicken or the egg?
