upgrading ASR 9010 IOS XR
Hisoma Sama
hello this is my first time upgrading ASR9k IOS XR
the usually method i used to do with normal IOS was with TFTP then reload the device and done " works like a charm"
now whats the deal with XR whats the easiest way and do i have to reboot whole device
and which one should i download from here https://software.cisco.com/download/home/282414851/type/280805694/release/6.6.3
i kinda got confused with installing/activating
thanks in advance
Mark Elsen
 - System upgrade procedure can be found below :
               https://community.cisco.com/kxiwq67737/attachments/kxiwq67737/5996-discussions-xr-os-and-platforms/9934/1/ASR9000_cXR_System_Upgrade_MOP_6.3.3.pdf
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks Marce1000
in the document they mentioned its from "5.3.4/6.0.x/6.1.x/6.2.x" to 6.3.3
what if i have below that like 4. is it the same procedure.
