08-02-2023
03:43 AM
- last edited on
08-06-2023
10:00 PM
by
Translator
I need to upgrade a
CSR1000v from 16.06.02
Can I go straight to the latest
Amsterdam-17.3.7
or will there be steps in-between?
TIA
Solved! Go to Solution.
08-02-2023 05:23 AM
Hi @jimmy10
It seems you need to be in 16.9 minimum.
You Can Upgrade to... |
From these Releases |
Cisco IOS XE Release 17.4.1a |
Cisco IOS XE SD-WAN 17.3.1a or later Cisco IOS XE SD-WAN 17.2.2 or later Cisco IOS XE SD-WAN 16.12.4a or later
Cisco IOS XE 17.3.x |
Cisco IOS XE Release 17.2.1r Cisco IOS XE Release 17.2.1v Cisco IOS XE SD-WAN 16.12.x Cisco IOS XE SD-WAN 16.11.x Cisco IOS XE SD-WAN 16.10.x Cisco IOS XE SD-WAN 16.9.x |
Cisco IOS XE Release 17.2.1r |
08-02-2023 05:23 AM
Hi @jimmy10
08-02-2023
06:25 AM
- last edited on
08-06-2023
10:02 PM
by
Translator
Hi Flavio,
Would it be safe to stay with the 16 track and upgrade to
16.12.x
and leave it there?
Or do I need to go to
17.x.x
08-02-2023
06:35 AM
- last edited on
08-06-2023
10:03 PM
by
Translator
Yes, I would recommend go to
16.12
first and then to
17.X
08-02-2023
06:42 AM
- last edited on
08-06-2023
10:04 PM
by
Translator
Hi Flavio,
Where do I get
16.12.x
from? I cant find it in software.cisco.com?
If it is discontinued, will I have to build a new instance with
17.x.x
