Upgrading Wan cards
terrelstinnett
Hay, i want to upgrade the wic cards on my 2600s, i am thinking this will be a cheaper option of making a frame-relay switch capable of supporting 6 other routers.
I'm not sure what type my serial port is. They take ethernet cables. I can tell you exactly what type of serial ports they are in the morning.
Is this a bad idea?
If so, do i just find a compatible card and plug and play or how does it work?
Leo Laohoo
Is this a bad idea?
Seriously?  It's as bad as it gets.
When  dealing with a 2600 couter, the phrase "plug-and-play" doesn't compute.
Never heard of a serial interface card that looks like ethernet "cables".  You mean blue color or the plug is like an RJ45?
At what speed (of your WAN) link are you trying to push?
Oh i remember you, youre the jerkface that always has super negative stuff to say on my posts.
Stay off my posts man. If youre the only help I can get I'd rather figure it out myself the hard way.
@leolaohoo
Hey Stanley,
The only "super negative stuff" I had to say about you was asking you to refrain from making multiple posts of the same subject matter.
The intention was to assist other people (including you) to know WHERE to post or WHICH threads to post.
As you wish.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
This for a lab?
