Using a Policy Map to both prioritise traffic and DROP unwanted traffic
petermann
Hi all,
Here's the problem. I want to drop all traffic except that defined in a policy-map. I'm using the policy map to serve two functions. Firstly to prioritize certain types of traffic and also to drop unwanted traffic by using NBAR.
Ok, here's an example. First the class maps:
class-map match-any platinum
match protocol rtp
class-map match-any gold
match protocol http
match protocol secure-http
match protocol dns
class-map match-any silver
match protocol smtp
match protocol pop3
match protocol secure-ftp
match protocol secure-pop3
class-map match-any bronze
match protocol ipsec
match protocol ftp
match protocol irc
class-map match-any drop
match any
and here's the policy map:
policy-map qos
class platinum
priority percent 20
set dscp ef
class gold
bandwidth remaining percent 30
set dscp 41
class silver
set dscp 31
class bronze
bandwidth remaining percent 10
set dscp 21
class drop
drop
I now apply it to my interface going out to the Internet:
interface dialer0
service-policy output qos
But, my problem is that as soon as it is applied, I can't surf the internet. However, as can be seen in the policy map, within the 'gold' class I have the following:
match protocol http
Furthermore, the 'gold' class comes before the 'drop' class. I've checked and every time I surf the internet, my web based packets are getting dropped by the 'drop' class. I don?t understand why this is!
To get around this, I have defined the following ACL:
access-list 150 permit tcp any any eq www
and added it to the 'gold' class.
match access-group 150
and it works, web traffic is detected by the ACL and output by the "Gold" service.
However, I?m not able to detect the web based traffic using NBAR (via the match protocol http command).
But the basic ACL worked. However, this is not ideal since it is vulnerable to programs like Skype masquerading as web traffic and tunneling out. Therefore, ideally I would like to capture the web traffic via NBAR using the 'match protocol http' command.
Does anyone know why this doesn?t work? or alternatively could suggest another best-practice method.
Any suggestions/help would be much appreciated.
Thanks.
- peter
23 Replies 23
Hi Mohammed,
That was very helpful thanks. As per you suggestion, I configured the following:
match protocol rtp
match protocol telnet
match protocol http
match protocol dns
match protocol smtp
match protocol pop3
match protocol ftp
match protocol irc
match any
policy-map classify_mark
class platinum
set dscp ef
class gold
set dscp 41
class silver
set dscp 31
class bronze
set dscp 21
class drop
set dscp 10
exit
interface fastethernet0
service-policy input classify_mark
end
Now when I do a "show policy-map inter fa0" I get "http" traffic being matched.
for example:
Class-map: gold (match-any)
1792 packets, 280523 bytes
5 minute offered rate 13000 bps, drop rate 0 bps
Match: protocol http
1409 packets, 193834 bytes
5 minute rate 2000 bps
Match: protocol secure-http
358 packets, 84753 bytes
5 minute rate 10000 bps
Match: protocol dns
25 packets, 1936 bytes
5 minute rate 0 bps
QoS Set
dscp 41
Packets marked 1792
So, the problem has been very much narrowed down. So I guess now the quesiton is why doesn't NBAR match the HTTP protocol on egress but does on ingress. Anyone got any ideas??
THANKYOU ALL VERY MUCH!
- pete
You are welcomed :) thats the solution i did to work around it, and i am in the process of searching for a reason.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Hi Mohammed,
The thing is, whilst it works I don't really want 2 policy-maps on the router.
Whilst my first example illustrated marking the packets with a DSCP value, this was just for the example.
What I really want to do is us the policy-map as an advanced traffic filter, which gives me fine control (using NBAR) on what protocols are allowed on egress, and dropping the rest.
A simple ACL on the fa0 ingress (only working up to L4) would be vulnerable to programs like Skype and P2P which will tunnel out of other allowed ports (like 80).
The added advantage of course is that I can also priorities traffic with a policy map. - Two benefits for the price of one!
If you do find a solution, please let me know.
Thanks again. All the best.
What type of router is this?
You are in the situation that QOS features in the ingress direction is not supported in the egress direction.
So you should set ip precendence input and do
match ip precendence on output.
Bjornarsb
Hi Bjornarsb,
I have tried this and classification of traffic on ingress works (even http), as illustrated in the previous post.
I realise best practice when applying QoS is to mark as close to source as possible, but in this scenario it is just a 1721 for a small office. I ideally do not want ?two? policy maps on a single router, one classifying and marking on ingress and other other applying scheduling on the egress.
I just want to drop traffic which doesn't match a "match protocol" statement using a policy-map applied to Egress. ? Essentially, a traffic filter using NBAR.
All the other protocols work, except "http".
All the very best.
- peter
OK, then I realy don't know. :)
By the way have you tried this:
hostname(config)# class-map http_traffic
hostname(config-cmap)# match port tcp eq 80
BR,
Bjornarsb
hi Bjornarsb,
I very much apprciate your comments.
I will try what you have suggested this evening.
However, we are just matching on port, and therefore I suspect Skype and other P2P apps will take advantage and tunnel out.
thanks though.
pete
Or you could try just to do this, just call the class and do what you want without a new match.
ip cef
class-map match-any dscp46
match ip dscp 46
class-map match-all telnet_ping_snmp
class-map match-all http
match access-group 154
class-map match-all pop3_smtp
match access-group 153
policy-map voice_traffic
class dscp46
shape average 30000 10000
class telnet_ping_snmp
shape average 20000 15440
class pop3_smtp
class http
interface FastEthernet0/0
ip address 10.10.247.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.1.1.1 255.255.255.0
service-policy output voice_traffic
Bjornarsb
Thanks Bjornarsb,
But your example doesn't have a class drop. for example:
drop
class dscp46
class pop3_smtp
class http
class drop
drop
you would need this to capture the rogue traffic. From my experiences, when you have the drop class at the end, your http traffic will stop working, despite matching http traffic BEFORE the drop class in the policy-map.
thanks anyway.
