Using ISDN as backup line for 878 router
naorelkayam
We started using the 878 router for our SDSL subscribers. Now, I noticed that it has an ISDN modem included (BRI0 interface).
How can I use it to act as a backup line?
I already know the commands for configure the backup interface. but what next?
how to make it dial with the user and password?
Thanks...
Naor Elkayam
6 Replies 6
from your post, it looks like you already have configured the BRI/Dialer interfaces on your router. Regarding the authentication, typically the commands 'ppp authentication pap' and 'ppp pap sent-username USERNAME password PASSWORD' are configured on the dialer interface. The username and password should have been given to you by your ISP.
If you post your configuration, I can have a look at what might be missing...
GP
Thank you for helping!!
Well, I only configured it to work as DSL router.
Tommorow I will make some configurations and post them here for you.
As I understood, these are the steps:
1. Configure the BRI0 as a backup interface
2. Configure the BRI0 (Dont know how but I will look)
3. Create a dialer interface with the commands that defines the number to dial and these two commands you gave me.
Is that correct? (more or less)
O.K, That's the sh run output:
Current configuration : 1117 bytes
version 12.3
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret ****
username **** password ****
no aaa new-model
ip subnet-zero
no ip routing
no ip cef
no ftp-server write-enable
isdn switch-type basic-net3
controller DSL 0
mode atm
line-term cpe
line-mode 2-wire line-zero
dsl-mode shdsl symmetric annex A
line-rate auto
interface BRI0
no ip address
no ip route-cache
encapsulation ppp
dialer pool-member 1
interface ATM0
backup interface BRI 0
ip address x.x.x.x 255.255.255.0
no ip route-cache
no atm ilmi-keepalive
pvc 8/35
broadcast
encapsulation aal5snap
bridge-group 1
interface FastEthernet0
no ip address
no shutdown
interface FastEthernet1
no ip address
no shutdown
interface FastEthernet2
no ip address
no shutdown
interface FastEthernet3
no ip address
no shutdown
interface Vlan1
no ip address
no ip route-cache
bridge-group 1
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer string *******
dialer-group 1
ppp pap sent-username **** password ****
ip default-gateway x.x.x.x
ip classless
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol ieee
line con 0
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
it looks fine.Can you paste the sh isdn status, sh isdn active and debug ppp auth logs if it isnt working?
you might want to change the 'backup interface bri0' statement to 'backup interface dialer0'. Also, make sure that you have two default routes with different administrative distances is your config:
ip route 0.0.0.0 0.0.0.0 atm0
ip route 0.0.0.0 0.0.0.0 dialer0 200
A common problem with backing up xDSL is that the main interface often does not go down when you loose connectivity. A workaround would be to create a tunnel and then to configure tunnel keepalives, as described in the document below:
Generic Routing Encapsulation (GRE) Tunnel Keepalive
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087cec.html
GP
here is a good example of a config set up on one of my routers - I am sure irt will help, I twicked it so Ican dial thru a NAS:
interface BRI0
ip unnumbered FastEthernet0
encapsulation ppp
no cdp enable
interface Dialer0
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer remote-name ******
dialer idle-timeout 100
dialer string **********
dialer-group 1
no cdp enable
ppp chap hostname
ppp chap password *******
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 0.0.0.0 0.0.0.0 Dialer0 100
access-list 1 permit any
dialer-list 1 protocol ip list 100
end
