packet loss
Kevin Hart
I have an interesting fault which is locking up telnet session when issueing certain commands i.e. "show run" works ok but "show proc cpu" always locks up the telnet session.
Routers are connected via frame-relay. A Colleague suggested pinging the other end of the frame pvc using different ping patterns which produced the following results.
data pattern specified within extended ping
aaaa 4040 5555
Packet size
100 100% 100% 100%
200 90% 86% 86%
300 0% 0% 0%
results show the success rate as a %
The following data patterns produced 100% success for the following packets sizes
100
200
300
400
500
600
1200
1400
1500
What is the significance with data patterns "aaaa", "4040" and "5555"
b.hsu
Level 5
Level 5
Packet loss caused by hardware problems is fairly easy to identify. This section uses the output of the show interfaces command to identify packet loss.
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00801545eb.shtml
bellocarico
Here a quick explanation take from the Un*x BSD site:
TRYING DIFFERENT DATA PATTERNS
The (inter)network layer should never treat packets differently depending
on the data contained in the data portion. Unfortunately, data-dependent
problems have been known to sneak into networks and remain undetected for
long periods of time. In many cases the particular pattern that will
have problems is something that doesn't have sufficient ``transitions'',
such as all ones or all zeros, or a pattern right at the edge, such as
almost all zeros. It isn't necessarily enough to specify a data pattern
of all zeros (for example) on the command line because the pattern that
is of interest is at the data link level, and the relationship between
what you type and what the controllers transmit can be complicated.
This means that if you have a data-dependent problem you will probably
have to do a lot of testing to find it. If you are lucky, you may manage
to find a file that either can't be sent across your network or that
takes much longer to transfer than other similar length files. You can
then examine this file for repeated patterns that you can test using the
-p option of ping.
Of course consider that this is meant for servers but the concept is the same.
Stefano
Also, another very good explanation of can be found here:
http://www.pmg.com/tip_archive/00_8_extping.htm
Please grade this post if you find it useful.
Stefano
