VACL or SVI AVL
nir.fisher
hi
could someone explain what is the difference between applying an ACL to an SVI on a switch or applying a VACL to a vlan?
thanks
6 Replies 6
rtjensen4
Level 4
Level 4
You apply an ACL to the SVI to control how traffic is routedBETWEEN VLANs on an L3 switch. An ACL applied to an SVI does nothing to control the traffic on the VLAN itself. The VLAN will carry whatever traffic is passed to it, with not filtering happening until it's routed.
Example:
This would deny any TCP traffic from VLAN1 to VLAN2
interface vlan1
access-group 1 in
interface vlan2
ip address 192.168.2.1 255.255.255.0
access-list 1 deny tcp any 192.168.2.0 0.0.0.255
The VACL is applied to a VLAN to control traffic WITHIN a VLAN. Ordinarily, you can't stop Host1 from talking to Host2 if they're connected to the same switch in the same VLAN. If they were in seperate VLANs, you could apply an ACL to the SVI to do it, but on the same VLAN, there's no filtering. This is where the VACL comes into play. The VACL applies to traffic in the VLAN. You can use a regular access-list or a mac-address access-list for this.
Example:
This would deny traffic destined to port 80 on vlan 1
vlan access-map test1 10
action drop
match ip address 110
access-list 110 permit tcp any any eq 80
vlan filter test1 vlan 1
Ryan
thanks , excellent stuff !!
youv' been allot of help
another question, if I apply a VACL to deny traffic to a certain host would that effect traffic coming to that host from a different vlan as well as
traffic from same vlan ?
VACL is  for intra VLAN traffic otherwise you use a RACL.
Regards.
thanks , but you didnt answer my question , would inter-vlan traffic to a certain host  be effected by an intra-vlan ACL regarding that host ?
Yes it would. A VACL applies to to all traffic within that vlan. Once the traffic is routed onto that vlan then the VACL will be applied.
Jon
thanks for all the help
