VC switch and configuration
anitaleung2019
Hi expert,
I will implement the video conf for top mgnt only. below is the requirement
1. only top mgnt can connect to the pre-defined ethernet switch.
2. for security reason, there is one NIC card for each PC of top mgnt
3. public internet, non top mgnt cannot access to VC switch
the contractor propose the PoC config as below. please help to review the configure to be feasible or not. mgnt users connect to "VC switch". detail please refer the diagram.
== question ===
Question
1. is it technical feasible?
2. VC traffic and non VC traffic can go right path, is it correct?
3. how to implement the layer 2 ACL (not layer 3 ACL) to block the 172.16.200.128 - 172.16.200.191?
---- config of "VC" switch ---
ip routing
ip route 0.0.0.0 0.0.0.0 --> layer 3 router
interface ge 1/0/1 - 1/0/5
descr to top mgnt PC
switchport access vlan 200
spanning-tree portfast
interface ge 1/0/10
desc connect to VC device
switcport access vlan 250
interface ge 1/0/24
desc to production network vlan 200
swithport mode trunk
switchport trunk allow vlan 200
interface vlan 250
descr VC vlan
ip address 172.16.250.1 255.255.255.0
interface vlan 200
descr production vlan
ip address 172.16.200.254 255.255.255.0
top mgnt PC setting
ip address range 172.16.200.16 - 172.16.200.31
default gw point to 172.16.200.254 ! VC switch
non top mgnt PC seting
ip address range 172.16.200.128 - 172.16.200.191
default gw point to another layer 3 router (172.16.200.1)
Hello Anita,
I'm sorry for late answer.
I think your VACL should have a third section to allow all other traffic to avoid the implicit deny any logic.
ip access-list extended ANY
permit ip any any
vlan access-map top_mgnt_VC
match ip address top_mgnt
action forward
match ip address non_top_mgnt
action drop
match ip address ANY
action forward
Hope to help
Giuseppe
Giuseppe Larosa
Hello Anita,
I try to provide answers to your questions
1) It is technically possible only if the production switch on the right has no knowledge of the VC subnet 172.16.250.0/24 that is on the VC switch. However, the internet facing router needs to know this subnet in order to make the VC device able to place and receive VC calls over the internet. From your network diagram the router R is connected to the production switch, if so the proposed configuration is not effective alone because the production switch will send traffic for unknown subnet to the router R and will receive an ICMP redirect to 172.16.200.254 to reach subnet 172.16.250.0/24. So the solution is not complete without using a VACL on the VC switch (see point 3).
2) VC traffic and non VC traffic can go the router R, but router R needs to know the VC subnet as explained above.
More technically the router R needs also to create a static NAT entry for the VC IP address with extendable option to make possible calls from the internet to the VC device.
3) how to implement the layer 2 ACL (not layer 3 ACL) to block the 172.16.200.128 - 172.16.200.191?
You need a VACL applied to Vlan 200. The VACL is applied to L2 Vlan 200 broadcast domain not to L3 SVI interface Vlan200 on VC switch.
As a reference you can use the following document
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/vacl.html?dtid=osscdc000283
without the VACL segregation of non manager users is not effective as explained above.
You need to deny traffic from hosts in range 172.16.200-128-191 to the VC subnet.
You need also to allow all other traffic to reach the VC subnet to allow VC calls with external devices.
To be noted if SVI Vlan 250 is not defined on production switch you can also solve with a routed ACL applied to SVI vlan 200 on VC switch.
If you want to avoid normal users to reach manager PCs IP address range you need a VACL.
Note :
requirement 3) may need to be redefined otherwise the VC device cannot make VC calls to device on the internet.
In my opinion the VC device should be able to be reached from the internet on appropriate TCP and UDP ports.
Hope to help
Giuseppe
Dear Giuseppe,
Thanks for your detail explanation and share your professional view on it. I prepare a VACL to be apply on the trunk interface of the VC switch. Please see if it is okay or not. Thanks
Anita
! set VACL to vlan 200 in VC switch
conf t
ip access-list top_mgnt
permit 172.16.200.16 0.0.0.15 172.16.250.0 0.0.0.255
ip access-list non-top_mgnt
permit 172.16.200.128 0.0.0.63 172.16.250.0 0.0.0.255
! apply VACL to VLAN 200
action forward
action drop
! apply VACL on vlan 200
vlan filter top_mgnt_VC vlan-list 200
copy run star
Hello Anita,
permit ip any any
action forward
action drop
action forward
Hope to help
Giuseppe
