Verizon Residential FIOS ONT - L2/L3 Switch - Dynamic PAT
HelpMePleaze
I have Internet only Verizon Residential FIOS. The Ethernet port is the active port (instead of the coaxial) on my Verizon Optical Network Terminal (ONT) box because I do not have TV service that uses coaxial connection.
I am trying to interconnect the ONT box's ethernet port and interface GigabitEthernet1/0/1 on my Cisco L2/L3 switch. The Verizon ONT box hands out a single public IP address using DHCP. My goal is to make dynamic PAT to work so that client computers on the inside private IP addressing subnets 192.168.0.0/24 and 172.16.0.0/24 are translated to the single public IP address.
Please take a look at my switch configuration (attached) to see what I am missing. Not sure if I am missing a default route or static routes.
Any suggestions are welcomed, thank you very much!
Hi Richard,
This is a 3750 switch running IP Service license. I was not able to make the
ip nat
working, that's why I am posting this to seek assistance. From the switch, I am able to ping 8.8.8.8 sourcing interface vlan 172 and I see the translation happening
 (show ip nat translation)
for the interface vlan 172 when I do that. However, the client PC is not able to ping 8.8.8.8 and I don't see any translation occurring.
my current setup:
ONT <<>> switch <<>> Client PC
Do I need to change the setup to
 ONT <<>> router <<>> switch <<>> Client PC?
7 Replies 7
Hello
Your configuration looks okay for PAT , Would suggest as this rtr is internet facing that you also hardened down the rtr possible with ZBFW or at least CBAC
Kind Regards
Paul
I would like to know what device this is. The original post describes it as L2/L3 switch. In general Cisco switches do not support nat. But the config does contain
 nat
commands. Can you check and see if
 nat
is really working?
Rick
Hi Richard,
ip nat
my current setup:
Thanks Paul for the suggestion. I am currently only using a L2/L3 switch. I may need to acquire a router to enable ZBFW.
what was connected to the ONT box before, a Verizon router ? Is your GigabitEthernet1/0/1 interface actually acquiring a valid DHCP IP address ?
George, yes the interface GigabitEthernet1/0/1 does acquire a valid public DHCP IP address
Hello
@HelpMePleaze wrote:
my current setup:
Yes - As
 Nat
isn't supported on 3750 switches so you would require a router in-between the ONT and the 3750 just like you have shown above
I assume this is after you've introduced the rtr  in-between the ONT and the switch, or are you getting the nat table off the ONT device?
Kind Regards
Paul
