Virtual Interface which used two physikal Interfaces
Kruemel2oo2
I 've got a cisco 2800 router with two connections to the internet. I use load balancing and I would like to
make a VPN Tunnel to a DMVPN HUB. The issue is that I only can use von Tunnel source.
Now my Question is it possible to make a virtual interface which used the two physikal Interfaces to the internet?
I hope you understand the issue.
regards Jörg
Lei Tian
Essentially, what you want is per packet load balancing instead of per flow, which is not recommended. With one tunnel interface, all packet will be encapulated with same source to destination; the per-flow load balance will only use one exit path.
Maybe you can try create two tunnel, source from different interface.
HTH,
Lei Tian
