Virtual router for vmware?
ricky89
I am looking for software for my virtual machines currently using a 4G LTE router.
I'm looking for a virtual router that I can surf the net from 100Mb similar to juniper VMX that I need to do where to start?
Can you give me some step by step guides.
Thank you.
2 Accepted Solutions
inderdeeps
Level 4
Level 4
@ricky89 : Cisco has CSR router as Virtual Instances. You can login with Cisco CCO ID and get the software below
https://software.cisco.com/download/home/284364978/type/282046477/release/3.15.0S
Jon Marshall
If it does not have to be Cisco specific you may want to look at VyOS which uses a similar syntax to Juniper and is free to use.
Jon
5 Replies 5
inderdeeps
Level 4
Level 4
Thanks for quick replies!!!
What are the ones for Cisco virtual router instance?
How much does currency cost in EUR thank you
Is there a possibility to change the bandwidth?
Jon Marshall
Jon
Is there a possibility to change the bandwidth? From  for cisco virtual router.
