VLAN assist...
Bruce Kenworthy
I have  the new VLAN that I wish to add to my existing network - 192.168.200.x. The new range will be 192.168.220.x
I have gotten only so far with my configuration on a Cisco 3750 stack (note - the config below) and also have  four 2960 switches in other parts of the building supporting the  rest of the network. My FW is a 5510... I put an inside route on that - "route  inside 192.168.220.0 255.255.255.0.192.168.200.233 1" - which I thought  would take care of things. The FW is 192.168.200.150 - the 3750 switch I am working on is 192.168.200.233.
My  thoughts were that I would add the 192.168.220.x to  the existing  192.168.200.x to increase my addresses - since I am running out.
Here's the 3750 as it stands - my problem is - I cannot figure what I need to make the new "220" addresses available to the same resources that VLAN1 has now. I can ping from a 192.168.200.x address to a laptop configured and connected to the 2/01 port on the switch - but cannot do much the other way.
Here is the switch info...
version 12.2
parser config cache interface
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime localtime
service password-encryption
hostname Company-370-c3750-1
boot-start-marker
boot-end-marker
logging buffered 65000 informational
logging rate-limit 1 except notifications
enable secret
username admin privilege 15
aaa new-model
aaa authentication login localauth local
aaa session-id common
clock timezone EST -5
clock summer-time EDT recurring
switch 1 provision ws-c3750g-24ts-1u
switch 2 provision ws-c3750g-24ts-1u
stack-mac persistent timer 4
system mtu routing 1500
vtp domain plexus
vtp mode transparent
authentication mac-move permit
udld aggressive
ip subnet-zero
no ip source-route
ip routing
ip icmp rate-limit unreachable 1000
no ip domain-lookup
ip domain-name plexusmg.com
no ip dhcp snooping information option
crypto pki trustpoint TP-self-signed-2443709824
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2443709824
revocation-check none
rsakeypair TP-self-signed-2443709824
crypto pki certificate chain TP-self-signed-2443709824
certificate self-signed 01
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
  quit
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig (STP)
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause pppoe-ia-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery cause small-frame
errdisable recovery interval 400
archive
log config
  logging enable
  logging size 500
  notify syslog contenttype plaintext
  hidekeys
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree logging
spanning-tree portfast bpduguard default
spanning-tree portfast bpdufilter default
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
vlan 220
name Printer
vlan 254
name Management
ip tcp synwait-time 5
ip ssh time-out 30
ip ssh version 2
interface Null0
no ip unreachables
interface Port-channel1
switchport mode trunk
switchport nonegotiate
logging event bundle-status
load-interval 30
storm-control broadcast level 20.00
spanning-tree link-type point-to-point
ip dhcp snooping trust
interface Port-channel11
switchport trunk native vlan 999
logging event trunk-status
load-interval 30
interface Port-channel12
load-interval 30
interface GigabitEthernet1/0/1
switchport mode access
spanning-tree bpduguard enable
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
load-interval 30
srr-queue bandwidth share 1 70 25 5
srr-queue bandwidth shape 3 0 0 0
priority-queue out
mls qos trust dscp
channel-group 11 mode active
interface GigabitEthernet1/0/26
load-interval 30
priority-queue out
mls qos trust dscp
interface GigabitEthernet1/0/27
load-interval 30
priority-queue out
mls qos trust dscp
channel-group 12 mode active
interface GigabitEthernet1/0/28
load-interval 30
priority-queue out
mls qos trust dscp
interface GigabitEthernet2/0/1
switchport access vlan 220
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
switchport port-security maximum 2
switchport port-security violation restrict
switchport port-security aging type inactivity
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
load-interval 30
priority-queue out
mls qos trust dscp
interface GigabitEthernet2/0/26
load-interval 30
priority-queue out
mls qos trust dscp
interface GigabitEthernet2/0/27
load-interval 30
priority-queue out
mls qos trust dscp
interface GigabitEthernet2/0/28
load-interval 30
priority-queue out
mls qos trust dscp
interface Vlan1
ip address 192.168.200.233 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan220
ip address 192.168.220.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan254
ip address 192.168.254.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.200.150
ip route 192.168.220.0 255.255.255.0 192.168.200.150
ip http server
ip http secure-server
ip sla enable reaction-alerts
snmp-server community PlexusMG RW
line con 0
line vty 0 4
exec-timeout 120 0
logging synchronous
transport preferred ssh
transport input ssh
transport output ssh
line vty 5 15
exec-timeout 5 0
privilege level 15
logging synchronous
transport input ssh
end
Thanks -
Bruce
lgijssel
Level 9
Level 9
Hi Bruce,
Again, your config for the vlan looks OK.
You must only configure ports into it. Example:
conf t
switchport access vlan 200
end
This will put the port in the new vlan, then configure ip addr & def gw and you should be good.
regards,
Leo
