VLAN DHCP to WAN http/https access
jking13602
New to IOS, working with an 819 ISR. I am trying to configure the VLAN DHCP for LAN switch port to access the WAN interface for HTTP/HTTPS. I assume this would be some kind of ACL or Access Group.
Current configuration : 2795 bytes
! Last configuration change at 20:32:47 UTC Fri Jul 18 2014 by test
version 15.3
hostname bob
boot-start-marker
boot-end-marker
aqm-register-fnf
logging buffered 51200 warnings
no logging console
no aaa new-model
crypto pki trustpoint TP-self-signed-476046398
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-476046398
 revocation-check none
 rsakeypair TP-self-signed-476046398
crypto pki certificate chain TP-self-signed-476046398
ip dhcp excluded-address 192.168.34.1
ip dhcp excluded-address 192.168.34.2 192.168.34.99
ip dhcp excluded-address 192.168.34.150 192.168.34.254
ip dhcp pool sdm-pool
 import all
 network 192.168.34.0 255.255.255.0
 default-router 192.168.34.1
 dns-server 8.8.8.8 4.2.2.2
 lease 0 2
ip domain name yourdomain.com
ip name-server 8.8.8.8
ip name-server 4.2.2.2
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid C819G-4G-V-K9 sn FTX182083AB
username cisco privilege 15 secret 5 $1$7bp8$MgueJzd0Gxu.fyyzGfJnS/
username test privilege 15 secret 5 $1$UbUY$1pNrtyLEV6g64a97hPWGC1
controller Cellular 0
interface Cellular0
 no ip address
 encapsulation slip
 dialer in-band
 dialer string lte
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface GigabitEthernet0
 ip address 192.168.0.122 255.255.255.0
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Serial0
 no ip address
 shutdown
 clock rate 2000000
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$
 ip address 192.168.34.1 255.255.255.0
 ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 199 interface GigabitEthernet0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0
access-list 100 permit ip 0.0.0.0 255.255.255.0 any
access-list 101 permit ip any 0.0.0.0 255.255.255.0
access-list 102 permit icmp any any
access-list 199 permit ip any any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 stopbits 1
line 3
 script dialer lte
 no exec
line vty 0 4
 login local
 transport input telnet
scheduler allocate 20000 1000
end
jking13602
Got it for now,
Added
VLAN 1
ip nat inside
Interface GigabitEthernet 0
ip nat outside
