Vlan mapping on 6500
sean baker
I'm looking to implement VLAN mapping for a proof of concept between two Cisco 6500.
One is running old Catos & the other IOS.
Config will look like this - does this look correct?
6500 CATOS
Interface gi1/2/1
set switchport mode trunk
set trunk encapsulation dot.1q
Set Switchport vlan mapping 101 561
6500 IOS
Interface gi1/2/1
switchport trunk encapsulation dot.1q
switchport vlan mapping enable
Switchport vlan mapping 561 101
on both switches do i need to prune all other vlans except for the ones i want to map?
Thanks in advance.
Giuseppe Larosa
Hello Sean,
as far as I remember CatOS does not support configuration contexts.
there is no configuration environment you can use set commands or show commands but without entering a specific interface just to make an example. Also interfaces had no names just like 1/1 and so on.
So I do not think your CatOS config template will work on the real device.
In addition, Vlan mapping may be a too new feature to be supported on the old device with CatOS.
I try to attach a configuration file for CatOS so that you can see what can be done.
Hope to help
Giuseppe
