VLAN question
coughlind
We have two Cat6509 switches as the core in a network distributing L2 VLANs accross Trunk uplinks to non-Cisco edge switches. The trunks have 802.1q and pass extended VLANs. We are seeing a problem with two new VLANs that we created, they appear to be fowarding in STP, but the IP we are running over the VLAN doesn't appear to connect over one particular uplink. This uplink was already in use prior to adding the new VLANs (1050 & 1060) and has been passing VLAN traffic just fine. I added 11050 and 1060 to other trunk uplinks, and we are able to pass the IP without any problem. the interface examples are below:
VLAN 1050 & 1060 do not pass IP
interface GigabitEthernet1/9
description Uplink to len-s2262-1
no ip address
load-interval 30
speed nonegotiate
switchport
switchport trunk native vlan 2997
switchport trunk allowed vlan 1040,1043,1047,1050,1060,1120-1122,1185
switchport trunk allowed vlan add 2009-2011,2018-2020,2047,2050,2060,2115,2250
switchport mode trunk
switchport nonegotiate
switchport vlan mapping enable
no cdp enable
VLAN 1050 & 1060 pass IP just fine.
interface GigabitEthernet2/4
description trunk to B109-1 port 3/18 (LEN Stack)
no ip address
load-interval 30
switchport
switchport trunk allowed vlan 1040,1043,1047,1050,1060,1120-1122,1137
switchport trunk allowed vlan add 1185-1188,1200,2008-2012,2018-2020,2027,2029
switchport trunk allowed vlan add 2030,2047,2050,2060,2108,2115,2200,2201,2250
switchport trunk allowed vlan add 2256-2260
no cdp enable
end
interface GigabitEthernet1/12
description Uplink to B120
no ip address
load-interval 30
speed nonegotiate
switchport
switchport trunk allowed vlan 1050,1060,1185,1186,1200,2010,2011,2020,2250
no cdp enable
end
interface GigabitEthernet1/24
description Link to KHHUB
no ip address
load-interval 30
speed nonegotiate
switchport
switchport trunk allowed vlan 1040,1050,1060,1120-1122,1185,2010,2019,2250
no cdp enable
end
I have already rebooted the edge switch and verified it is running the same code as the other edge switches. It is a Baystack 470.
Any thoughts or suggestions?
5 Replies 5
lgijssel
Level 9
Level 9
Have you checked the config on the Baystack?
It could be that the vlanID is not existing on it or not bound to the corresponding interface.
regards,
Leo
I verified that the VLAN ID is on the edge switch and is being tagged on the trunk port.
Tnx, Dave.
Kevin Dorrell
Level 10
Level 10
It strikes me that 1040 and 1050 are quite low numbers, and quite close to the magic 1025 where the internal VLANs start. Do you have any layer-3 routed interfaces that might be using these VLAN allocations already? Do a show vlan internal usage to find out.
Kevin Dorrell
Luxembourg
This is the output for that command:
VLAN Usage
1006 online diag vlan0
1007 online diag vlan1
1008 online diag vlan2
1009 online diag vlan3
1010 online diag vlan4
1011 online diag vlan5
1012 PM vlan process (trunk tagging)
1013 L3 multicast partial shortcuts for VPN 0
1014 Egress internal vlan
1015 Egress internal vlan
1016 GigabitEthernet1/1
1017 GigabitEthernet1/3
1018 vr0
1019 GigabitEthernet2/43
1020 GigabitEthernet2/5
1021 GigabitEthernet1/5
1022 GigabitEthernet2/7
No other L3 interfaces using those tags. I did create two additional VLANs, 2050 & 2060, and got the same result. I just couldn't pass the IP accross those VLANs on that uplink.
coughlind
Well, this was an issue of incorrect documentation here. The active uplink was on the 2nd core Cat6509 instead of the 1st. I added the VLANs to the appropriate uplink, and it works.
Thank you for your replies and help.
Dave.
