VLAN's on Cisco Router 857
samirshaikh52
Level 2
Level 2
Hi Community,
Is is possible to create VLAN's on a Cisco Router 857.
Thanks for the help
8 Replies 8
Leo Laohoo
Yes as long as you are using ONLY VLAN 1.  850 will support only ONE (1) VLAN.
Please don't forget to rate our useful post or mark this thread as "Answered".  Thanks.
Thanks for the response.
It means there is no way to add vlans more than 1 on this router
With the current 12.4 IOS, the answer is NO.
However, try downloading the 12.3 IOS and see.  I don't have an 850 here with me to test.
Hi Leo,
I've upgraded the IOS version but still nothing happened.
Can you post the version and the name of the IOS you are using?
sh ver | inc bin
Reza
Hi Reza,
output of the said command:
boot system flash c850-advsecurityk9-mz.124-15.T14.bin
Have you tried using 12.3 IOS?
Hi Leo,
Thank you for the update.
Yes, I have tried.
