VLAN with a Cisco 1721 router and HP Procurve 4000M switch
valleyvet
I have a Cisco 1721 router and a HP Procurve 4000M switch that I'm using to setup two VLANs.  I have configured the router as shown below and have one port on the Procure 4000m set as a trunk and others tagged for one or both vlans.  My problem is that I cannot ping the router or ping between two machines on the same subnet.  Have I set something wrong or are these two pieces of equipment not capable of VLANs.
version 12.3
hostname vlan
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$n8Uj$a3V1.e1IewoOCwFoUYON7/
enable password xyz
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
interface FastEthernet0
no ip address
no ip split-horizon
speed auto
full-duplex
interface FastEthernet0.1
encapsulation dot1Q 1 native
ip address 172.16.1.1 255.255.255.0
no ip redirects
interface FastEthernet0.5
encapsulation dot1Q 5
ip address 172.16.5.1 255.255.255.0
no ip redirects
interface FastEthernet0.10
encapsulation dot1Q 10
ip address 172.16.10.1 255.255.255.0
no ip redirects
interface Serial0
no ip address
ip broadcast-address 0.0.0.0
shutdown
no cdp enable
ip classless
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password xyz
login
end
6 Replies 6
Reza Sharifi
Not familar with HP, but is it configured correctly?
also
can you remove native and try again.
Hi Jeremy,
Can you post the configuration of the HP ProCurve as well? The router seems to be configured correctly.
This will probably not be possible: the native keyword is added automatically to that command. The native keyword would be removed only if a different VLAN was designated as the native VLAN on this tagged routed port.
Best regards,
Peter
Hi Peter,
You are correct, when you create sub-interface with dot1.q 1, it will add the native to it.
But you can delete vlan 1 with sub-inter 1 and add a different one.  In that case it does not add the native to any of the other sub-interfaces.
here I have 3 sub-interface with no native:
interface Ethernet1/0.20
encapsulation dot1Q 20
ip address 20.20.20.1 255.255.255.0
no snmp trap link-status
interface Ethernet1/0.30
encapsulation dot1Q 30
ip address 30.30.30.1 255.255.255.0
interface Ethernet1/0.40
encapsulation dot1Q 40
ip address 40.40.40.1 255.255.255.0
You are correct that the native keyword is added automatically.  I have tried it without interface fa0.1, just 5 and 10, but still no luck.
As far as the procurve config, I don't know of a good way to show the config.  I have tried tagging ports to just 1, 2, and all three VLANS with no change.  I have the option to set the trunk to the following types.
– Trunk (Source Address/Destination Address trunk; the default type if you do not select a type)
– SA-Trunk (Source-Address trunk)
– FEC (Fast EtherChannel
trunk)
I have tried all three options with no luck on any.
can you try testing without trunking it?  In this way you just need an IP an the main interface with no sub-interface and configure the HP port as an access port with one vlan..
Reza,
I removed the sub interfaces and gave an ip to the main interface and that allows me to see the router thru the HP switch.
Jeremy
