Dear Experts,
I need to restrict the Interent BW fot the two Proxy server.
Topology Dia is attached here :
I am suggesting the following configuration to be applied on LAn interface of Interent Router in outside direction.
Can you please suggest is it ok? Will it work?
class-map match-any Proxy_1
match access-group name Proxy_1
class-map match-any Proxy_2
match access-group name Proxy_2
class-map match-any class-default
match access-group name DEFAULT
policy-map Proxy_Restriction
class Proxy_1
police 20000000 3750000 7500000 conform-action transmit exceed-action drop violate-action
drop
class Proxy_2
police 15000000 2812500 5625000 conform-action transmit exceed-action drop violate-action
drop
class class-default
interface GigabitEthernet0/1
Description *** LAN Interface ***
service-policy output Proxy_Restriction
ip access-list extended Proxy_1
permit ip any 1.1.1.1 0.0.0.0
ip access-list extended Proxy_2
permit ip any 1.1.1.2 0.0.0.0
ip access-list extended DEFAULT
remark EXPLICIT CLASS-DEFAULT
permit ip any any
