Vlans on small sites with no core switch
mano.hernandez
I have several small sites that are part of an MPLS network. Most of the sites have Cisco 1921 routers that are handing out DHCP for about 6 machines. Looking to add VOIP at these sites and thought about doing VLANS, but don't want to spend money on a layer 3 switch since we are going to do POE.
What would be the proper way to do this for those smaller sites?
Config:
Here is the config.
hostname Site_A
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp excluded-address 10.13.16.0 10.13.16.100
ip dhcp pool Site_A
network 10.13.16.0 255.255.255.0
domain-name
dns-server 10.13.5.35 10.13.5.32
default-router 10.13.16.1
lease 60
ip cef
license udi pid CISCO1921/K9 sn FGL154720V6
redundancy
class-map match-any COS3-NON_Critical_APPS
match access-group name COS3-Traffic
class-map match-any COS2-Critical
match access-group name COS2-Traffic
class-map match-any COS1
match ip dscp ef
match protocol rtp
policy-map COS
class COS1
  priority percent 20
  set ip dscp ef
class COS2-Critical
  bandwidth remaining percent 80
  set ip dscp af31
class COS3-NON_Critical_APPS
  bandwidth remaining percent 10
  set ip dscp af21
policy-map CE_EGRESS_SHAPING
class class-default
  shape average 9856000 39424 0
  service-policy COS
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex full
speed 100
service-policy output CE_EGRESS_SHAPING
interface GigabitEthernet0/0.50
description .AT&T CIRCUIT ID
encapsulation dot1Q 50
ip address 172.16.1.230 255.255.255.252
ip flow ingress
ip flow egress
interface GigabitEthernet0/1
ip address 10.13.16.1 255.255.255.0
duplex auto
speed auto
router bgp 65007
no bgp log-neighbor-changes
network 10.13.16.0 mask 255.255.255.0
neighbor 172.16.1.229 remote-as 13979
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-export source GigabitEthernet0/0
ip flow-export version 5
ip flow-export destination 10.13.5.169 2055
ip access-list extended COS2-Traffic
permit tcp any host 10.13.5.132
permit tcp any host 10.13.5.37
permit tcp any host 10.13.5.51
permit tcp any host 10.13.5.116
permit tcp any host 10.13.5.90
ip access-list extended COS3-Traffic
permit tcp any host 10.13.200.10
permit tcp any host 10.13.5.67
snmp-server community NxCP21ac RO
snmp-server location Anywhere, AL
snmp-server contact
snmp-server enable traps tty
snmp-server enable traps entity-sensor threshold
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 2ckaMp79
login
transport input all
scheduler allocate 20000 1000
ntp server 10.13.5.35
end
Site_As#
Your posting seems to assume that doing vlans requires a layer 3 switch. That is not the case. Doing vlans does require a switch but it could be a layer 2 switch or a layer 3 switch. If you have a layer 3 switch you have the advantage that inter vlan routing can be done on the switch and it reduces the load on the router. But layer 3 switch is not required. With a layer 2 switch you configure the multiple vlans, assign access ports to vlans, and configure one switch port as a trunk and use that to connect to the router. On the router you configure a subinterface for each of the vlans and use the router both for routing between the vlans and for connectivity to outside.
From your preceding response it seems that you have two reasons to want to change to an environment that uses vlans. That would require a switch for each site but could be layer 2 or layer 3.
Rick
Rick
7 Replies 7
Richard Burts
Your 1921 has two interfaces both of which are used. If your want to implement VOIP it seems to me that you have two options.
1) use vlans with one for the existing data traffic and one for VOIP. This would require provisioning a switch at the site and using a trunk port on the switch to connect to the 1921.
2) combine phones and hosts in the existing subnet.
Rick
Rick
Joseph W. Doherty
" . . . thought about doing VLANS, but don't want to spend money on a layer 3 switch since we are going to do POE."
How do you understand VLANs, L3 and PoE intermix?
Regardless, for so few hosts, I would suggest you just go with Rick's 2nd suggestion, i.e. have data hosts and VoIP on same network. (What a VoIP dedicated VLAN provides you, generally an easy way to control traffic to/from a VoIP network, if you so chose. If also shields VoIP devices from processing data host broadcasts.)
I guess, I should say I've never done router on a stick.
So I've created VLANS on a layer 3 switch and done the interVLAN routing, but never configured sub-interfaces.
The other issue is that all our sites have wireless with a company SSID and then a guest SSID, but they are all on the same network, which I have been looking to fix as well. (Previous setup by the Network Guy)
So, I want to create
VLAN 80 -Voice
VLAN 60 - Guest Access
VLAN 16- Data.
Even our bigger sites that have 20-40 employees, everyone is on the same VLAN and if there is a layer 3 switch, it isn't being used.
Rick
Rick
Thanks for that.
Glad that our responses and suggestions have been helpful. Thank you for marking this question as answered. This will help other participants in the forum to identify discussions which have helpful information.
Rick
Rick
What a L3 switch provides is much more capacity for on-site routing, which if almost all your flows need to go out a branch WAN router, does little for you.
As Rick describes, using a router for local routing with a L2 switch is pretty straight forward.
Even for 40 employees, with 80+ hosts, for network capacity you still should be fine with a single VLAN. Generally, on switches, the traditional class C, or /24, isn't too big.
Again, though, if you envision the need to control traffic between groups of users and/or hosts devices, than different VLANs/networks help to manage that.
Keep in mind, everything in a network has trade-offs. When you create more VLANs/networks, you now have more sloshing around in your L3 topology, which can create their own set of problems.
From what you've described, so far, you would probably want to have your "Guess Access" in a separate VLAN/network, but you likely could, if desired, keep your data and VoIP hosts in the same VLAN/network.
