Voice over frame issue...
asmith
Ok, we use 3662 at hq's to connect to 1760-v's and have t-1's to each location... have a store that everything works; data, voice out, but voice in does not...
here is info from 1760:
Store129#sh dial-peer voice sum
dial-peer hunt 0
AD PRE PASS
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET PORT
1 pots up down 7129 0
2 vofr up up 7... 0 syst Serial0/0:0 10
3 vofr up up 5... 0 syst Serial0/0:0 10
4 vofr up up 3.. 0 syst Serial0/0:0 10
3662 shows the following for the vofr circuit:
VoiceOverFRPeer73
information type = voice,
tag = 73, destination-pattern = `7129',
answer-address = `', preference=0,
numbering Type = `unknown'
group = 73, Admin state is up, Operation state is up,
incoming called-number = `', connections/maximum = 0/unlimited,
DTMF Relay = disabled,
modem passthrough = system,
huntstop = disabled,
in bound application associated: DEFAULT
out bound application associated:
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
type = vofr, session-target = `Serial1/0 129',
called number = `',
session-protocol = cisco-switched,
fax-rate = voice, payload size = 30 bytes
fax NSF = 0xAD0051 (default)
codec = g729r8, payload size = 30 bytes,
signaling-type = cas,
VAD = enabled,Voice Sequence Numbers = disabled,
voice class perm tag = `'
Connect Time = 0, Charged Units = 0,
Successful Calls = 0, Failed Calls = 5, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "2F ",
Last Disconnect Text is "no resource.",
Last Setup Time = 491492.
as you can see 3662 shows "NO RESOURCE"
1760 shows protcol donw, but have replaced FXS card at location, same issue???
where can i look?
AL
asmith
Here is debug from 3662, if that helps...
*Mar 1 01:57:24.303: ccswvoice: callID 339 pvcid 129 cid 27 state O/G INIT event I/C PROC
*Mar 1 01:57:24.307: ccswvoice: callID 339 pvcid 129 cid 27 state O/G PROC event I/C REL
*Mar 1 01:57:24.311: ccswvoice: callID 339 pvcid 129 cid 27 state O/G PROC event O/G REL
here is another debug command i found and it's output:
*Mar 1 02:06:39.499: ccswvoice_call_setup_request: Setting up call 364 dest
*Mar 1 02:06:39.499: ccswvoice_process_event: Event id 0x0 started at 14500971
*Mar 1 02:06:39.499: ccswvoice: callID 364 pvcid -1 cid -1 state NULL event O/G SETUP
*Mar 1 02:06:39.499: ccswvoice_out_null_setup: callID 364
*Mar 1 02:06:39.499: ccswvoice_initialize_ccb: Entered
*Mar 1 02:06:39.499: ccswvoice_out_callinit_setup: callid 364
*Mar 1 02:06:39.499: ccswvoice_out_callinit_setup: callID 364 using pvcid 129 cid 31
*Mar 1 02:06:39.499: ccswvoice_send_setup: callID 364 on pvcid 129 cid 31, called number 7129
*Mar 1 02:06:39.499: ccswvoice_process_event: Event id 0x0 ended at 14501679
*Mar 1 02:06:39.543: ccswvoice_pkt_handler: message type 0x2 cid 31
*Mar 1 02:06:39.543: ccswvoice_process_event: Event id 0x9 started at 14545583
*Mar 1 02:06:39.543: ccswvoice: callID 364 pvcid 129 cid 31 state O/G INIT event I/C PROC
*Mar 1 02:06:39.543: ccswvoice_in_callproc: callID 364 pvcid 129 cid 31
*Mar 1 02:06:39.543: ccswvoice_process_event: Event id 0x9 ended at 14545805
*Mar 1 02:06:39.551: ccswvoice_pkt_handler: message type 0x4D cid 31
*Mar 1 02:06:39.551: ccswvoice_process_event: Event id 0xE started at 14554938
*Mar 1 02:06:39.551: ccswvoice: callID 364 pvcid 129 cid 31 state O/G PROC event I/C REL
*Mar 1 02:06:39.551: ccswvoice_in_release: callID 364 pvcid 129 cid 31 cause 0x7
*Mar 1 02:06:39.551: ccswvoice_in_release: callID 364 pvcid 129 cid 31 call state O/G PROC
*Mar 1 02:06:39.551: ccswvoice_send_release_comp: callID 364 on pvcid 129 cid 31 cause 0x7
*Mar 1 02:06:39.551: ccswvoice_process_event: Event id 0xE ended at 14555404
*Mar 1 02:06:39.555: ccswvoice_call_disconnect: Entered
*Mar 1 02:06:39.555: ccswvoice_process_event: Event id 0x5 started at 14556517
*Mar 1 02:06:39.555: ccswvoice: callID 364 pvcid 129 cid 31 state O/G PROC event O/G REL
*Mar 1 02:06:39.555: ccswvoice_out_release: callID 364 pvcid 129 cid 31 cause 0x2F
*Mar 1 02:06:39.555: ccswvoice_out_release: callID 364 pvcid 129 cid 31 call state O/G PROC
*Mar 1 02:06:39.555: ccswvoice_call_cleanup: callID 364 pvcid 129 cid 31
*Mar 1 02:06:39.555: ccswvofr_store_call_history_entry: Entered
*Mar 1 02:06:39.555: ccswvofr_store_call_history_entry: cause=2F tcause=2F cause_text=no resource.
*Mar 1 02:06:39.555: ccswvofr_store_call_history_entry: 0 pkts received, 0 pkts sent on dlci 65535 cid 255 callid 364
*Mar 1 02:06:39.555: ccswvoice_process_event: Event id 0x5 ended at 14557361
*Mar 1 02:06:45.259: ccswvoice_call_setup_request: Setting up call 367 dest
*Mar 1 02:06:45.259: ccswvoice_process_event: Event id 0x0 started at 20262373
*Mar 1 02:06:45.259: ccswvoice: callID 367 pvcid -1 cid -1 state NULL event O/G SETUP
*Mar 1 02:06:45.259: ccswvoice_out_null_setup: callID 367
*Mar 1 02:06:45.259: ccswvoice_initialize_ccb: Entered
*Mar 1 02:06:45.307: ccswvoice_in_progress: callID 367 pvcid 75 cid 7
*Mar 1 02:06:45.307: ccswvoice_process_event: Event id 0xB ended at 20308822
*Mar 1 02:06:45.307: ccswvoice_bridge: bridging calls src 367 dst 366 pvcid 75 cid 7 state O/G PROCccfrf11_caps_ind: codec(
preferred) = 16
debug ccswvoice vofr-detail ce vofr-detail ccswvoice vofr-detail ug ccswvoide
b
ce vofr-detail
CCSWVOICE Vofr Detail tracing is disabled
3662_HQ#
AL
try voice rtp send-recv
I'd like to see the configs.
