08-01-2011 06:10 AM - edited 03-04-2019 01:08 PM
We have a remote site which has a 3G router. The site is able to connect to the Head Office via 3G. We wanted to have couple of phones at the site. The phone is registering with the Call Manger@ HO. But the voice from the remote site takes atleast 4 - 5 seconds to reach the HO, while the HO office voice reaches instantly at the remote site. The phones are configured to using G729 codec. What could be the issue?
We have applied the below QoS for voice, is this correct?
class-map match-any VOICE
match access-group name VOICE
match ip rtp 16384 16383
match access-group name Signaling
policy-map VOICE
class VOICE
priority percent 80
class class-default
bandwidth percent 20
interface Cellular0/3/0
service-policy output VOICE
ip access-list extended Signaling
permit tcp any any eq 2000
permit tcp any eq 2000 any
permit udp any any eq 2000
permit udp any eq 2000 any
permit tcp any any eq 2001
permit tcp any eq 2001 any
ip access-list extended VOICE
permit ip 10.88.130.16 0.0.0.15 any
Cisco website says that they tested and were successful with 10 simultaneous call over the 3G connection.
Thanks in advance.
08-01-2011 06:24 AM
you are applly the signaling and RTP in the same class
you need to make it as bellwo fro example
class-map match-all VOICE
class-map match-all SIG
policy-map VOICE
class VOICE
priority percent 75
class SIG
priority percent 5
class class-default
also what is your interface actual bandwidth you might need to shape it to the actual provided bandwidth to get your QoS policy kiikced in
see the bellow document for more details about this point
https://supportforums.cisco.com/docs/DOC-8373
if helpful Rate
08-04-2011 04:26 AM
Thanks for the reply marwanshawi,
Its a 3G connection, so bandwidth varies based on signal strength and range. That is why we are using percent.
08-04-2011 05:20 AM
but you need to defiine a value so that your QoS policy will reference this value and consider your linke conjested or not otherwise you might not get the QoS policy kicked in
if helpful Rate
