VPN client connection to GNS3 router no ping pass
adnane dakna
                   Hello ,
I setup a lab scenario for IPSEC remote access using Cisco client under GNS3 , the topolgy of my lab is quiet simple , we connect router to my loopback PC card and cisco client use preshared key to establish session to router , I success to establish connection and  I get IP address from pool configuration , but I was unable to ping loopback interface of my router , the problem seems to be related to my PC because  no packets are captured when I do ping from PC to router's loopback (20.20.20.20.20) , briefly , IPsec session established but without any reachbility from Pc to router (icmp).
Router configuration :
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable password cisco
aaa new-model
aaa authentication login AAA-VPN local
aaa authorization network AAA-VPN local
aaa session-id common
memory-size iomem 5
ip cef
username adnane password 0 adnane
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group vpnall
key adnane
pool VPNPOOL
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dynamp 10
set transform-set myset
crypto map dynamp client authentication list AAA-VPN
crypto map dynamp isakmp authorization list AAA-VPN
crypto map dynamp client configuration address respond
crypto map dynamp 10 ipsec-isakmp dynamic dynamp
crypto map vpn client authentication list AAA-VPN
crypto map vpn isakmp authorization list AAA-VPN
crypto map vpn client configuration address respond
interface Loopback0
ip address 20.20.20.20 255.255.255.255
interface FastEthernet0/0
ip address 10.10.10.2 255.255.255.0
duplex auto
speed auto
crypto map dynamp
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
ip local pool VPNPOOL 30.30.30.1 30.30.30.254
ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
control-plane
line con 0
line aux 0
line vty 0 4
end
5 Replies 5
Abzal
Level 7
Level 7
You need to add split tunnel to able access to internal network
access-list 120 permit ip 20.20.20.0 0.0.0.255 30.30.30.0 0.0.0.255
http://www.cisco.com/en/US/tech/tk59/technologies_configuration_example09186a00800a393b.shtml#con4
Best regards,
Abzal
the feature split tunneling allow us to access internet and remote LAN VPN simultaneously, normaly when we apply access list to our crypto , the default route in our PC to VPN virtual adaptor is removed , but my problem is not access at same time to internet and VPN , I'm stuck to pass ping packets from PC to loopback router , even we have default gateway is our VPN adaptor when doing wireshark between VPN adaptor and GNS3 routers no icmp packets pass in both ways.
Are you able to ping looback Interface form Router
Jawad
yes sure
Hello ,
actually it work for me , but instead of using MS loopback interface to connect my cisco client to GNS3 router , I use VMnet8 and I launch cisco VPN client from VM machine , the ping pass from VM machine to router without problem , may be it is issue from MS loop back interface..
Thanks for all.
