Vpn Connection Establish and access internet but Cannot Access Local LAN
adeel0680
version 12.4
hostname Router
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login abc1 local
aaa authorization network abc2 local
aaa session-id common
resource policy
ip cef
username cisco password 0 cisco123
crypto isakmp policy 10
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp client configuration group cisco
 key test123
 pool vpnpool
crypto ipsec transform-set set1 esp-3des esp-md5-hmac
crypto dynamic-map map1 10
 set transform-set set1
 --More--
Router#sh run
Building configuration...
Current configuration : 1273 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
aaa new-model
resource policy
ip cef
 encr 3des
 hash md5
 group 2
 key test123
 pool vpnpool
 reverse-route
crypto map map1 client authentication list abc1
crypto map map1 isakmp authorization list abc2
crypto map map1 client configuration address respond
crypto map map1 10 ipsec-isakmp dynamic map1
interface GigabitEthernet0/0
 ip address 202.163.70.204 255.255.255.248
 duplex auto
 speed auto
 crypto map map1
interface GigabitEthernet0/1
 ip address 192.168.0.235 255.255.255.0
 duplex auto
 speed auto
ip local pool vpnpool 192.168.0.232 192.168.0.234
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
scheduler allocate 20000 1000
end
8 Replies 8
Julio E. Moisa
You need to create an ACL to allow the access to the internal services, it should be applied  to crypto isakmp client configuration group cisco,
ip access-list extended VPN-CLIENTS  <--It will represent the access to internal services.
permit ip <source> <destination>
acl <ACL name>
acl VPN-CLIENTS
https://www.tunnelsup.com/remote-access-vpn-connection-using-a-cisco-router/
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Current configuration : 1704 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
aaa new-model
resource policy
ip cef
 encr 3des
 hash md5
 group 2
crypto isakmp client configuration group abc2
 key test123
 pool vpnpool
 acl 101
 reverse-route
crypto map clientmap client authentication list abc1
crypto map clientmap isakmp authorization list abc2
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic map1
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
ip local pool vpnpool 192.168.50.1 192.168.50.50
ip route 0.0.0.0 0.0.0.0 202.163.70.201
ip http server
ip nat inside source list 111 interface GigabitEthernet0/0 overload
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 101 deny   ip any any
access-list 111 permit ip any any
access-list 111 permit icmp any any
control-plane
line con 0
line aux 0
line vty 0 4
 password esmletih123
line vty 5 15
end
ACL define but still cannot access Local Lan
I see a default route configured on the router, do you have entries into the routing table for the LAN networks?
basically lan network for internet is deploy in tplink device which is linked with layer 2 switch and from layer 2 switch , i have linked router with this local lan switch with same Lan ip scheme 192.168.0.0/24.
I have find another issue which i want to share in pic, vpn client show local lan disable please review and guide me.
Lan network scheme is 192.168.0.0/24 and already define in router lan interface.
 ip nat inside
 duplex auto
 speed auto
why i will need of routing table for lan network.
this is (what I think) the access lists should look like:
access-list 101 permit ip 192.168.0.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 111 deny 192.168.0.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 111 permit ip 192.168.0.0 0.0.0.255 any
Access list 101 allows traffic from the VPN pool to the LAN. Access lists 111 denies traffic from the VPN pool to be NATted, but allows traffic from the LAN.
whether it is possible problem is at isp end because it is working fine with zong isp at home.
Julio is right, your access lists are not right. They should be:
